ok here is an image, this wing is my mimicry of a williams profile so it's not a real profile:PNSD wrote:Yup.shelly wrote:ringo, the lowest pressure line is near the leading edge even for a cambered wing. Forget Venturi.
Ringo, the method you state is not incorrect, I believe it's known as inverse design? Developed initially whilst looking at transonic aerofoils. However turbine, and compressor blades have probably found the best use of such methods.
Leading edge droop on A/C reduces the peak suction magnitude, and in doing so reduces what would be a large adverse pressure gradient.
It's from early 2010, f duct days, so it has a little pressure bleading on the back of the flap, but ignore that.
whether it's not curved enough i couldn't say. But take into account the high static pressure on the leading edge.
