hardingfv32 wrote:Where is your central air source? It can not be in the nose per the rules.
Brian
Why? Most of the teams use a hole in the nose.
"3.7.8 Only a single section, which must be open, may be contained within any longitudinal vertical
cross section taken parallel to the car centre line forward of a point 150mm ahead of the front
wheel centre line, less than 250mm from the car centre line and more than 125mm above the
reference plane.
Any cameras or camera housings approved by the FIA in addition to a single inlet aperture for
the purpose of driver cooling (such aperture having a maximum projected surface area of
1500mm2 and being situated forward of the section referred to in Article 15.4.3) will be exempt
from the above."
