New squarer tyres for 2012 by Pirelli
DaveW
DaveW
239
Re: New squarer tyres for 2012 by Pirelli
shelly wrote:I think the aero issue which is made reference to it is not whre to shift aero load to comply with tyre force characteritics, it is instead related to the vortices developed by the shape of the tyre itself and their interaction with the car shape from an aero point of view
Probably correct, but the mechanical tyre issues required (in Renault's case) a shift in c.g. position of at least 7 percent. I venture to suggest that this and the consequent aero changes were major compared with the tyre profile change.
italian
italian
Pirelli 2012
Pirelli 2011
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
Federico
Federico
the profile looks exactly the same
The 2011's have a more gradual curve at the end of the "tread", the 2012's have a sharper transition from "tread" to "sidewall"
raymondu999
It's a very very subtle difference. I doubt it'll be even anything to see/talk about on the track
失败者找理由,成功者找方法
piast9
piast9
I can't see any difference too. Maybe Pirelli made the tyre squarer when looking from the side, not the front. Just to make the show better...
raymondu999
失败者找理由,成功者找方法
hardingfv32
hardingfv32
Measure the shadows being cast on the surface. One is about 15% bigger than the other. I am assuming equal inflation pressures.
Brian
raymondu999
Considering the backdrops; we have to assume very unequal lighting though.
失败者找理由,成功者找方法
italian
italian
Interesting.. I get how pressure and temperature is recorded but how is tyre wear recorded?
raymondu999
Yeah that's what I thought too. Surely if you wanted to measure wear you'd have to measure how much tread you have left? I can sort of believe monitoring degradation; if Pirelli constantly monitor the tyre temperatures and sort of run their own live simulation; from which they work out deg; but wear? How?
失败者找理由,成功者找方法
italian
italian
If someone get acquainted with Hembery he will be able to ask him. :D
I think a sensor is applied on the valve of the tyre for knowing pressure and temperature but for the wear... No idea.
Since I've read the article I've been thinking about this solution.
Edit: Moreover this technology will be introduced in "normal" cars!
raymondu999
I don't think you'll even need that - Paul Hembery is very sociable and answers any questions you tweet him.
失败者找理由,成功者找方法
italian
italian
raymondu999 wrote:I don't think you'll even need that - Paul Hembery is very sociable and answers any questions you tweet him.
Yes but, in my opinion, he can't reveal how the system works, I think it's secret.
