DaveKillens wrote:But maybe it's better to cover it with a warmer as soon as it comes off the car, and keep that tire at an elevated temperature until it is required again, even for the race. That way, you avoid having the tire going through a complete heat cycle, when it's better to just keep it warm for 48 or 72 hours.
Not sure I agree with this line of reasoning. Admittedly there isn't much opportunity to chase down such things in a controlled manner. But to me, a heat cycle is just heat history. Temperature goes up.. stays there a while.. goes down. Area under the curve is your heat history. You add history (and with it change x-links etc) with either a lot of these cycles, or by just holding at elevated temperature indefinitely. Hence my earlier comment that I don't think such a thing would necessarily be good for performance.
marcush. wrote:The tyre is not really cured when you get it ..So the curing process is interupted at best so to speak when you collect the black gold at the tyre supplier.
Not sure I agree with this either. On what are you basing the "not really cured" bit? Or how are you defining "cured." ? I'd argue that most race rubber is actually fairly well "cured" or stable when you get it, relative to green (uncured) rubber anyway. Otherwise you'd go through too much of a change in your early running or the thing just wouldn't have the guts to survive. I'd speculate it would just fall apart to crap.
Or put it this way.. why would a tire manufacturer produce an undercured (let's call it "not yet stabilized") "hard" tread when you could just make a stabilized soft tread?
Now admittedly the process will certainly continue once you take possession of the thing and start running around on it. But I'm just not comfortable with saying that race treads are typically "undercured" ... even though such theories have come up in literature. Either way Ben probably has a better feel for this aspect of things than I.
For the race proper maybe you don´t really need ultimate grip for one lap but a bit of stamina .....so maybe it´s worth considering to deliberately heat them up a bit more at somewhat higher temps for a defined time to get them a bit more cured without taking the rubber off ...so maybe 2 hours @110°C ,anyone?
Such is the premise behind heat cycling tires before a race. Trade some peak performance for longevity.
