Tire Heat
strad
117
Re: Tire Heat
hmmmmmmmm thanks stez90. not sure there is any more info though. glad to have the vids thanks
Sir Stirling Moss
Re: Tire Heat
so where is the problem? I would have been surprised if williams or Force india would have had no issue in present all detail of the thermal imaging so using a awkward range not representing the whole picture is just a normal thing when you are
in fear of having some sensitive information passed to the opposition...it´s a bit like Lewis twittering some data plots....is it sensitive -yes.does it help the opposition ? forget it .You see the result of a multivariable input leading to a crash ...
one example of what you can do with software to fiddle an infrared (grey!) video into a thermogrphy -color- the fancy colors are a processing thing- so of course you can "mend" it but the general information is present.
[youtube]http://www.youtube.com/watch?v=GRJtKOYqa-w[/youtube]
Blanchimont
Blanchimont
214
Re: Tire Heat
Today's thermal images of Massa's rear tyres showed a different temperature range IMO. Let's wait for the videos to appear on youtube, i couldn't find a video so far.
Re: Tire Heat
Blanchimont wrote:Today's thermal images of Massa's rear tyres showed a different temperature range IMO. Let's wait for the videos to appear on youtube, i couldn't find a video so far.
you don´t know how if the calibration parameters for the colors are the same from race to race and from team to team -i certainly would change this randomly for pictures intended for publication ... :wink:
You cannot compare the colors -as the coloring is a generic feature of the software - without all base information about the measuring setup all you can judge is what is happening in the videostream you are presented and try to correlate it with known parameters from that run -for example engine water temperature ,maximum allowable temperature for cf parts /or failure temperature of automotive paint systems...etc etc
strad
117
Re: Tire Heat
What do you think of the spot on the upright that Matchett thought was internal piping for hydraulics?
I don't think so,,,not the way that IF setup is working..I think it's heat coming off the rear wheel/tire...did you see the narrow yellow band coming off the tire at about that height?
Sir Stirling Moss
Re: Tire Heat
strad wrote:What do you think of the spot on the upright that Matchett thought was internal piping for hydraulics?
Is the relevant capturing available here -I think most people do not know what you are talking about.
Blanchimont
Blanchimont
214
Re: Tire Heat
The first three pictures show the front tyres of Alonso, the very first in the pit lane, the second at the end of the pits and the third during the first cornering.
The next images show Massa's rear on the track, first one is on the straight, the other two under braking/cornering/accelerating. Colder tyre areas are blue in this screens, then there is some lilac and finally orange/yellow.
Blanchimont
Blanchimont
214
Re: Tire Heat
Here is the video, over 2 minutes of finest thermal imaging :)
Even the track surface gets brighter/warmer behind the car!
Edit:
http://www.dailymotion.com/video/x14z09o_sing_auto
stez90
stez90
Re: Tire Heat
private video?
Blanchimont
Blanchimont
214
Re: Tire Heat
Edit: Link to dailymotion now in my post above.
Re: Tire Heat
wow ,cool find ....thanks for sharing. :D
stez90
stez90
Re: Tire Heat
Massive sidewall heating under acceleration. Due only to traction stress or even exhaust flow at wide open throttle? :?:
Front wheels don't show that under braking stress.
strad
117
Re: Tire Heat
When I follow the link I see no thermal imaging :wtf:
Sir Stirling Moss
Re: Tire Heat
strad wrote:When I follow the link I see no thermal imaging :wtf:
:mrgreen: selective coloration -I told you so - :mrgreen: for me it´s very impressive coloration changes ....maybe i read too much into it? :wtf:
Blanchimont
Blanchimont
214
Re: Tire Heat
Sorry, the link to Dailymotion is down!
Let's see for how long this video is available...
or download it here.
