I don't think the FIA are the most brilliant people in the world, but I don't see their rule changes as evidence of utter incompetence.
Many rule changes were introduced to contain speeds, not help overtaking. Narower track cars will go around corners slower (that's simple physics) and will be faster on the straights, which should increase braking distances (need to get to a slower speed from a higher one). Grooved tyres - daft idea. The stepped bottom forces a measurable and un-cheatable gap between the underside of the pod and the road (remember what happened in the 1980's when the specified a gap!
) Two race engines daft execution, but the right direction.
So what if the cars are faster this year - imagine where they would have been with last years regs - the FIA have contained speeds without making the cars too slow.
If they revert to rules from previous decades where there was overtaking - with what teams have learned in aero and tyre tech (not to mention electronic diffs etc.), the speeds will be huge AND I suspect, overtaking even harder.
IMHO - driver aids need to go (TC for one) and it would be great if paddle shifts went with it (perhaps they should at least ban all electronic control of the shift and clutch apart from simple actuation of the mechanism - that would include banning the "kickers" that match engine revs when changing gear) and keep a manual clutch (whether foot or hand).
As for the aero CDG idea, at least they recognise that dirty air behind the cars makes following another car very hard to do. If they remove all aero then F1 will no longer be the fastest on the planet (and no sponsor space
), so they can't do that and expect to keep the premier slot on TV. Whether this is the right solution, we don't know - I see it as a big signpost pointing at the problem. Something that the engineers need to look at.
Don't forget, with the proposed wing location downforce and corner speed will be cut dramatically, along with increased braking distances and cars running closer in corners - which should make for better racing. So, what is wrong with that?
I don't see why discussing an idea has to turn into a rant against the FIA.
