sry, mokey seat is allowed.an actual car you have to photograph and that is not as easy as it might sound if you want a PR worhy result and also is hugely time consuming...gilgen wrote:these are just computer generated pictures and need not be necessarily what will be seen on the eventual car. for instance, the rear wing appears to have a large plane, and there is evidence of a monkey seat, which is supposedly not allowed.
it is a pity that teams are "announcing" their cars using computer images or photoshop images. why can they not actually produce the actual car? maybe a bit of tomfoolery?
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
only one I remember is Lotus, the rest never used renders or they were correct when they showed them officialy as the new car (not the teasers).F1 Technical @f1technical
I'm coutious of over-analysing these car renderings. Previous years have shown the eventual cars usually end up to be quite different #F1
It will make the rear wing generate more down force!rssh wrote:Why is the exhaust ending in front of the monkey seat? Is it just because it is just a rendering or there can be some body work after exhaust exit .
5.8.5 There must be no bodywork lying within a right circular cylinder which :
a) Shares a common axis with that of the last 150mm of the tailpipe.
b) Has a diameter 30mm greater than the tailpipe.
c) Starts at the exit of the tailpipe and extends rearwards as far as a point 600mm behind the rear wheel centre line.
The tail light must be placed at least 595mm behind the rear wheel centre line, so you're talking about the exhaust being 5mm behind the tail light, and hence behind almost all of the rear wing structure (likely only end plates behind there) The exhaust being in front of the monkey seat is deffinately not allowed.astracrazy wrote:where the exhaust has to be is further forward than you'd expect. I'd say its right from what you see
what?beelsebob wrote:The tail light must be placed at least 595mm behind the rear wheel centre line, so you're talking about the exhaust being 5mm behind the tail light, and hence behind almost all of the rear wing structure (likely only end plates behind there) The exhaust being in front of the monkey seat is deffinately not allowed.astracrazy wrote:where the exhaust has to be is further forward than you'd expect. I'd say its right from what you see
Also, the box for the monkey seat begins at 500mm behind the rear wheel centre line – so we're deffinately talking about 10cm behind the monkey seat here.
Agree, except on one point. Exhaust must have an angle between 0º and 5º on vertical axis and be along longitudinal axis.astracrazy wrote:what?beelsebob wrote:The tail light must be placed at least 595mm behind the rear wheel centre line, so you're talking about the exhaust being 5mm behind the tail light, and hence behind almost all of the rear wing structure (likely only end plates behind there) The exhaust being in front of the monkey seat is deffinately not allowed.astracrazy wrote:where the exhaust has to be is further forward than you'd expect. I'd say its right from what you see
the exhaust must extend to 170mm to 185mm behind the RWCL. so a monkey seat can go behind it....or actually under as you'd need to angle the exhaust +5deg so its not in the 'cone'
