I'm have a little difficulty understanding this, Where are you having the fuel vaporize? in the fuel line itself or in a separate chamber?ian_s wrote:but surely with the necessary reduction in pressure to cause vaporization, there won't be a big enough pressure gradient for the fuel to be injected?Abarth wrote:This is intriguing.gruntguru wrote:I just had another thought. Reducing the pressure in the lines will cause lighter components of the fuel to vaporise if the pressure is reduced below the vapor pressure of that component. This would potentially allow ALL THE FUEL between the flow meter and the pump at the engine to be used for a short term power boost.
A combination of flexing fuel lines, and playing with the pressures, could well give some remarkable "boost".
And one other thing what effect if any will the race in Mexico have on the fuel usage see how it is over 1 mile above sea level
