Well, N-26, while the serious forces imposed on the track by F1 tyre inputs must contribute some,Noetiepoerker26 wrote: ↑24 Apr 2017, 10:37Some commentator said that the bumpyness of the track was in some way caused by Formula 1 cars running on it. Could someone explain this, or is it just utter BS?
Off topic: I know it's not completely true, but i like it as a quote neverthelessJ.A.W. wrote: ↑24 Apr 2017, 10:48
FYI, your legend about 2 strokes VS 4 strokes aint right...
.. as a fact check of the comparative BMEP figures of the best N/A G.P. machines, 2T VS 4T, will clearly show.
N/A 4Ts must compensate for this torque deficit by turning extreme rpm, the very opposite of your idea..
Not that any other category is not contributing to the bumps, but yes, F1 causes more bumps than any other similar (is vehicle size) category, due to aero allowing the cars to corner and brake producing around 5G. That causes a lot of stress in the tarmac, much more than any other category without aero, so the usual process of any tarmac becoming bumpy is shortened by F1 carsNoetiepoerker26 wrote: ↑24 Apr 2017, 10:37Some commentator said that the bumpyness of the track was in some way caused by Formula 1 cars running on it. Could someone explain this, or is it just utter BS?
With turbulent jet ignition on the 4 stroke engines and direct injection the initial ultra lean combustion can be followed with multi phase combustion, injecting more fuel at maximum heat release, 8-12 atdc maintaining more constant cylinder pressure increasing torque per cycle with minimal friction due to favourable crank rod angle. The increased compression ratio providing high efficiency.Noetiepoerker26 wrote: ↑24 Apr 2017, 17:39Off topic: I know it's not completely true, but i like it as a quote neverthelessJ.A.W. wrote: ↑24 Apr 2017, 10:48
N/A 4Ts must compensate for this torque deficit by turning extreme rpm, the very opposite of your idea..![]()
Actually Marc, no..Muniix wrote: ↑26 Apr 2017, 13:08With turbulent jet ignition on the 4 stroke engines and direct injection the initial ultra lean combustion can be followed with multi phase combustion, injecting more fuel at maximum heat release, 8-12 atdc maintaining more constant cylinder pressure increasing torque per cycle with minimal friction due to favourable crank rod angle. The increased compression ratio providing high efficiency.Noetiepoerker26 wrote: ↑24 Apr 2017, 17:39Off topic: I know it's not completely true, but i like it as a quote neverthelessJ.A.W. wrote: ↑24 Apr 2017, 10:48
The old rules of thumb completely change, using cylinder pressure sensor and Gigaflops of compute now available calculating losses minimising them and maximising torque. The optimal strategy is identified.
They fixed the Hubble deep space telescope this way.
Why do you have to make such a fuzz about it? I know it's not correct, why should I change it? It's fiction.
Maybe because this is a technical forum, & not a "fiction" forum?Noetiepoerker26 wrote: ↑26 Apr 2017, 15:35Why do you have to make such a fuzz about it? I know it's not correct, why should I change it? It's fiction.
