Andres thanks for the reply in regards to spanish law
Just for certainty, am i reading right then that
A > if you're off-grid, you don't need no tax in any way, whatever the case
B > so essentially, i can have enough solar panels that generate right below 10 kW 'the restriction', and for example store that in a battery set 'the tank' to infinite, so, theoretically, 10 hours of sun, everything works nominal, i have enough batteries to store, and the net energy produced and stored at the end of the day is 100 kW (or, atleast, 99.99 kW.)
in other words, i can have 5 airconditioning units running, fridge, freezer, computers, batteries charging, tv, all on, as long as i'm keeping SOLAR consumption under 10kW, and additionally, i could pull 10kW from the energy grid?
BUT do i in every case need the permits fixed?
that's where i'm still in the blind spot.
do i need permits and 'legislation' (administration) done if i stay under 10kW, or do i need to have that anyway,
and does that ALSO go if am off-grid or would that only apply on-grid?
