No, you can compare air inlets of SF90 and this Haas + photo with Grosjean sitting in the car 2020. SF90 has a pointed top and a rounded bottom.
Weird crankcase breather. Vertically right of the rain light. Used to be under it.RZS10 wrote: ↑06 Feb 2020, 17:37The images are photoshopped to hide any details in dark areas, unfortunately
https://i.imgur.com/y4NhiaL.png
The old trick was to open in new tab and add :orig at the end but now twitter just gives you the max. image size right away, which is cool ... in this case 4096x2304Wouter wrote: ↑06 Feb 2020, 17:25If you click on a photo in the Twitter message, you will even get the photo on your entire screen.bauc wrote: ↑06 Feb 2020, 16:23same photos but bigger on the link below
https://www.motorsport.com/f1/news/haas ... s/4681194/
Haas use the same suspension as the Ferrari at the beginning of the season, not sure if they get any upgrades.
Yes the new Ferrari will most likely have the same suspension.ScrewCaptain27 wrote: ↑06 Feb 2020, 20:36Haas use the same suspension as the Ferrari at the beginning of the season, not sure if they get any upgrades.
That separated steering rod looks like it could hugely influence the barge board flow structure in lower speed/high lock corners...MtthsMlw wrote: ↑06 Feb 2020, 20:57Yes the new Ferrari will most likely have the same suspension.ScrewCaptain27 wrote: ↑06 Feb 2020, 20:36Haas use the same suspension as the Ferrari at the beginning of the season, not sure if they get any upgrades.
Some things to note:
-more extrem (or noticable) POU offset
-steering rod now separate of the top wishbone
-X & Z axis position looks to be the same
