Ferrari SF23
Holm86
249
Re: Ferrari SF23
Venturiation wrote:
14 Feb 2023, 13:21
front wing changes
https://pbs.twimg.com/media/Fo7FTVTXsAA ... ame=medium
So they are actually using the Mercedes strakes on their front wing now
Re: Ferrari SF23
Sidepods tightened front and back, smaller cooling exits, smaller louvers, loads of little details all over the car. Such details always mean confidence in basic design and performance. Front wing change is quite big, I didn't expect this. Will do a bigger comparison in the evening, quite a lot has changed vs final F1-75 spec.
Re: Ferrari SF23
Vanja #66 wrote:
14 Feb 2023, 13:26
Thoughts on the inlets below sidepod inlets? They might vent beside halo into bathtub?
Re: Ferrari SF23
14 Feb 2023, 13:27
Impossible to tell right now. Could be just very long vanes ending just in front of the undercut.
Front wing strakes are curious, if they keep them then they've aligned with FIA on design and other teams will soon follow.
Goblin42
57
Re: Ferrari SF23
there's some cool stuff behind the halo to clear the cockpit losses
is that legal ?
F1ern
F1ern
16
Re: Ferrari SF23
Im glad that they did not jump on the RB copy wagon. They continued their design. There are so much more details, love it.
Schippke
Schippke
Re: Ferrari SF23
[quote=organic post_id=1111113 time=1676373898 user_id=44197]
So they have inlets at the undercut and outlets behind the halo. Is this a new duct loophole :lol:
[/quote]
New Chassis S-Duct? Because the one from the front-nose was just too mainstream previously. :mrgreen:
Unlikely... but could they be showing the front wing with all the strakes on it to distract everyone from other parts of the car?
Re: Ferrari SF23
Goblin42 wrote:
14 Feb 2023, 13:29
is that legal ?
Haas had a bit smaller vanes there last year, so it's legal
Re: Ferrari SF23
Vanja #66 wrote:
14 Feb 2023, 13:31
Goblin42 wrote:
14 Feb 2023, 13:29
is that legal ?
I think it was tombazis was talking about how they had initially closed off things like this but decided to loosen the rules around the cockpit/halo for vanes as they didn't make a big difference to the wake
Xyz22
Xyz22
124
Re: Ferrari SF23
Cardile said the evolution compared to the F1 75 is very big.
Andi76
Andi76
445
Re: Ferrari SF23
tpe wrote:
14 Feb 2023, 12:56
So, this is the car that was supposed to be an upgrade in 2022, but budget etc etc etc etc.
I cannot believe that this is the 2023 car! I mean, it's almost the same as the 2022 car!
Well, let's face it - the F1-75 was the fastest car in 2022. The race trim was the problem. So if you've worked out the bugs in that regard, made better use of the tires, reduced drag - then surely an evolution was better than building a radically different car. The front wing looks even more center loaded with more outwash. The underbody intake has been modified and moved back a bit, as has the smaller intake of the sidepods, the lower element of the front wing has been offset and the nose is now only attached to the second element. So there are plenty of detail changes here even at first glance. Personally, I think it's absolutely the right decision to make an evolution of an obviously very good concept, and improve it in the crucial places. This is how you actually win world championships - not by copying or constantly changing your concept! Especially when you already have a very good and especially fast one, which only had a few "teething troubles"!
I also honestly do not understand how you can be disappointed here - all the other teams have done nothing but copied Ferrari and Red Bull, while Ferrari has remained true to its line and has further developed its concept! That's a lot better than if you had now like all the others to their own concept still copied Red Bull!
Goblin42
57
Re: Ferrari SF23
johnny comelately
johnny comelately
110
Re: Ferrari SF23
To me when there was a little bit of speed it looked strong from low revs, stable, compliant and balanced. There seemed to be some misleading audio manipulation.
Re: Ferrari SF23
This rectangular opening below the sidepod inlet is weird for sure. Same sort of size as the opening behind the halo. The sidepod just outwashes continuously outboard of it, ie it's not just a vane but an inlet into the sidepod
Xyz22
Xyz22
124
Re: Ferrari SF23
Vanja #66 wrote:
14 Feb 2023, 13:26
Did they change the front suspension?
