slimjim8201 wrote:Back on topic...
I am a firm believer in aerodynamics...just not for the FSAE application. The speeds just don't get high enough to generate any appreciable amount of downforce. Most teams get more "downforce" from the weight of the wings and undertray than the actual aerodynamics. Many teams will quote 200 pounds at 65 mph or 100 pounds at 50 mph. Let me be the first to say BS.
The maximum speed that you encounter on an FSAE endurace course is right around 60 mph. None of the turns can be taken at that speed. The max turning speed is much closer to 30-35 mph. Look at all of the best and fastest teams...Cornell, Western Australia, Penn State, Virginia Tech...no aero devices.
I think your evaluation is perhaps dated?
100 lbs at 50 MPH is certainly not BS if properly designed. A rear wing well within the rules could achieve most of that. Our FSAE car is barely over 300 lbs . . . the downforce we feel we can easily generate at even 35MPH will have a *significant* effect on the cornering capabilities, but perhaps more importantly, the balance of the car. If you were at Fontana for FSAE West last year I think you'd find that the cornering speeds in the Endurance runs are quite higher than 25 MPH.
Your argument that all the best teams do not run Aero has very little to do with Aero at all. It says almost nothing about Aero, rather that great teams can out do poor ones with good suspensions and high budgets. That Cornell wins without Aero doesn't mean that they wouldn't be faster if they incorporated Aero into the car.
There are significant design points awarded for Aero, and our team was reamed by the judges for having absolutely zero of it. There are benefits like high speed stability and tuneability aero provide outside of pure performance as well.
Most teams get more downforce from the weight of the compoents? Aero does "nothing" but add weight? Please. Our rear wing setup weighs under 12 pounds and we'll have results from on car testing once the fuel injection is up and running . . . You can call BS then
