xpensive wrote:Ciro Pabón wrote:I think this is an excellent question. It's not in the definitions. You only have this as an approximate definition:
I think Drawing 7, page 63 of 63, in the FIA Technical regulations makes it crystal-clear.
Oh, c'mon. You think, you think...
Snille och Smak!
I wrote that in 2007... Here you have the same drawing in my
carefully conserved 2007 technical regulations: if you see the reference plane you can shot me with your älgstudsare
I named this picture NoReferencePlaneIn2007Regs because... yes, you guessed it: there was no reference plane to be seen at all in any drawing in the 2007 Tech Regulations
For the benefit of the forum I post the latest technical regulations that I have at hand.
March 2006 F1 Technical Regulations
December 2006 F1 Technical Regulations
January 2007 F1 Technical Regulations
December 2005 Draft of 2008 F1 Technical Regulations
April 2007 Draft of 2008 F1 Technical Regulations
February 2008 F1 Technical Regulations
April 2008 Draft of 2009 F1 Technical Regulations
July 2008 Draft of 2009 F1 Technical Regulations
February 2009 F1 Technical Regulations
March 2009 Technical Regulations (showing alterations)
July 2009 Stable 2010 F1 Technical Regulations (Clean)
Please, note that the names are not mine, those are the names, once upon a time, given in FIA site ("clean" regulations? Did they publish dirty ones?).
Now, regarding tolerances, there are a few paragraphs, interred in the Annexes (do not
make me give you the links to the annexes...
AND NO! I AM NOT YELLING! IT'S JUST THAT I AM SPANIARD! NO, I AM NOT ANGRY EITHER! IT'S CAPSLOCK FRIDAY!).
Beneath the reference plane lies the skid block (or 'plank' as it is better know to Grand Prix fans), which must run from the frontmost point of the reference plane (33cm behind the front wheels) to the rear wheels. It is made out of a material with a specific gravity of between 1.3 and 1.45, and must measure 30cm in width, with a tolerance of 0.2cm. Although it decreases in thickness towards the edges to allow a smooth design, the plank most importantly, when measured through six pre-cut 5cm diameter holes, has a tolerance of just one tenth of a centimetre on its 1cm thickness.
Those who doubt (I know who you are:
all of you) remember Belgian GP, 1994.
Schumacher Disqualified Again at Belgian Grand Prix
Now, as for inclined plane of reference, dig (and dig hard!) and you'll find this:
... the surfaces must be 'uniform, solid, hard, continuous, rigid, and impervious'
Now, in Spanish, uniform means
uniform... one form. Una forma, Gran 747.
Finally (whew!) I have been in a leave of absence, but once in a while I check and post briefly, no more than 2000 or 3000 words, I swear, and I read around here that the changes for 2011 said something like this:
- The article forbidding team orders (39.1) is deleted. Teams will be reminded that any actions liable to bring the sport into disrepute are dealt with in the same way that FIA deals with any article by Rubython or News of the World...
... blah, blah, blah ...
- A better definition of the reference plane, and reinforcement of bodywork deflection tests, especially at the front of the reference plane
