Interesting thread.
Of course karts uses track width as a tuning tool. The lack of suspension maybe make people think there is not much to tune there but nothing in the world is as wrong as that. Kart tunning is as difficult as any other race car tunning. The rear axle works as a beam, flexing between the wheel and the bearings. You can choose what diameter and thickness of axle use and also how many bearings youll use (2 or 3) and how they are going to be fixed. You can change rear wheel hubs to make that working axle shorter or longer, you have
got torsion bars in the front and in the rear
etc, etc, etc...
Heres a very cool Kart setup guide by Arrows:
http://www.dpeng.com.au/files/arrow/arr ... manual.pdf
Jersey Tom is wrong not only because he believes track width is not generally used as a chassis tuning tool, but also because he thinks that you can balance a kart with air pressure split.
At least with the rubber we use arround here, you cant use other tyre hot pressures than 13 to 14 psi. They are used to balance nothing. Tyre compounds are very sensitive to temperature and the over pressures make tires work in an undesired temp range. Overpressured tires literally turn into a "glass" appearence in matter of few laps, while very underpressured tires have walls not rigid enough and there is always the danger of loosing the tire.
Also, take a look at that manual for wet setup advices
and you´ll see track width setup is fundamental there.
