xpensive wrote:But you still have some work to do in xplaining the two plotted graphs, which led you to a four-decimal relation between front- and rear stiffness?
Where are those values coming from and what are those graphs supposed to prove anyway?
X, I generated the plots from rig tests of various F1 vehicles. As I (e)xplained in the legend, each point is the average of between 30 & 100 stiffness estimates extracted during one rig test. The points don't represent a completely consistent set, because I didn't choose the test conditions (pressures, temperatures, camber, vehicle weight, "aero" down force, etc. were all the choice of the various customer teams). Lots of caveats to be made about rig test estimates, of course. I can only state that the estimates shown were obtained using a consistent and highly repeatable procedure.
What is interesting (I think) is way the results fall into two distinct sets and, within each set, the consistency of the rear/front ratio for results spanning several generations of tyre (& tyre manufacturer, for the first set). Apologies for the number of significant figures shown in the slopes of the two Excel-generated trend lines (linear, & forced through 0,0) - that was down to Microsoft & my neglecting to override default settings.
I wasn't trying to "prove" anything, as such, I was simply providing historical information in response to the OP's request. Be interesting to see if simulations can detect performance differences between the two sets (hint: the second set will require a more forward c.g. & aero bias than the first). I would appreciate feedback on that aspect.
WB, You did answer my question, thank you. You posted whilst I was still fumbling with my request. I'm afraid you were incorrect with your assumption about the stiffness of the current front tyre, & I suspect that the assumptions you made to predict a stiffness for the 2010 front tyre may not be entirely accurate either (with apologies), although I'm sure aero specialists would wish it so.
