Bravely put, JT. If I may put one of your statements the other way around (kind of, anyway), a car that has roasted front tyres will be tight. Of course it will. I recall that NASCAR's have (or used to have) an air blower installed in the right front wheel well, allowing a driver to cool an over-heated tyre & recover, or at least reduce, an imbalance (push) whilst on-track.Jersey Tom wrote:Seems like this is "reaching" a bit.. lot of 'ifs' and speculation.. and the temperature effect is surprisingly difficult to sort out with any amount of confidence.
In any event, in my experience a car that has a noticeable balance problem will typically have higher temps at the axle lacking grip. Understeer works the fronts harder than the rears by itself. Tight cars push front temps up and roast them, loose cars push rear temps up.
Beside that.. whatever temp change you get purely from the extra load of shifting the CG forward a couple inches... I don't think you'd even notice it.
I'm afraid it is a fact that c.g. position affects the way tyres are worked. I could reel off many examples but, to keep it short, I will just say there is a reason for installing the fuel cell of an F1 car at its centre of gravity. I believe Peter Wright discussed the topic in "Formula 1 Technology".
