wesley123 wrote:On the other hand you are just preventing flow over the diffuser, so on that part there is nothing gained nor lost.
For next year, when Red Bulls crash box shape wont be legal anymore, an Pull Rod would make less sense, as you are having the space higher upwards due to the more regulated space, but you place it lower limiting flow over the diffuser.
How do 2 skinny rods prevent flow over the diffuser?
Look how clean this is (green lines):
nothing blocking the diffuser, and very good flow to diffuser. No pesky suspension parts in the way.
Side pods/engine cover don't have to cover suspension parts, so they can terminate much earlier.
compare to this:
1/3 of the beam wing blocked from high speed flow. Sidepods also need to be shaped to condition flow over these parts as well.
Mcalren will be ignorant not to try push rod suspension on the interim car at least. Worst that there a no more DDD, where under car space is a priority.
