A true F1 Connoisseur needs not corner numbers. We can count to 20 if the occasion calls for it. In this case 14 is the maximium and well within reach.Diesel wrote:Why have you used a map that doesn't have the corner numbers? Crazy
A true F1 Connoisseur doesn't need any stinking maps – instead, he knows the corner names by heart, along with their radii, width and girlfriend's name.andrew wrote:A true F1 Connoisseur needs not corner numbers. We can count to 20 if the occasion calls for it. In this case 14 is the maximium and well within reach.Diesel wrote:Why have you used a map that doesn't have the corner numbers? Crazy
Well, "proper" circuits have corner names rather than numbers. Only these new-fangled circuits have numbers...beelsebob wrote:A true F1 Connoisseur doesn't need any stinking maps – instead, he knows the corner names by heart, along with their radii, width and girlfriend's name.andrew wrote:A true F1 Connoisseur needs not corner numbers. We can count to 20 if the occasion calls for it. In this case 14 is the maximium and well within reach.Diesel wrote:Why have you used a map that doesn't have the corner numbers? Crazy
also, When I was young....
andrews wrote:Pit lane time loss: 18.5s
Try counting the Shanghai corners, not an easy task.andrew wrote:A true F1 Connoisseur needs not corner numbers. We can count to 20 if the occasion calls for it. In this case 14 is the maximium and well within reach.Diesel wrote:Why have you used a map that doesn't have the corner numbers? Crazy
The corner numbers are a minor detail.Diesel wrote:Try counting the Shanghai corners, not an easy task.
