Of course it isn't.FrukostScones wrote:I doubt that the flow is jumping the vane to reach the slit, maybe the flow is split by the vane,
[Expect the irate reply from those obsessed with it in 3-2-1]
Whether it does or doesn't, I'm not quite sure obviously, but both of these pictures come from the same place. However the slit/cut would be there for the purpose of getting some flow under the floor. As you said, perhaps it splits the flow?FrukostScones wrote: last week the flow looked like this (I know the spec is a bit different, but the inside vane stays in place.)
I doubt that the flow is jumping the vane to reach the slit, maybe the flow is split by the vane, but I doubt that this Piola guess is correct. We have seen on Maldonated's car the power/direction of the exhaust flow.
Can this really work without a device speeding up the air between the 2 holes?blokkie wrote:
Only on the sauber it's entry and exit is on the nose itself .
I think that 90° corner has to do with the mechanical bits at the front of the survival-cell.mep wrote:Why should the flow there go around a 90° corner?
It has some inertia and high air speed. It will create lots of turbulence for very little flow going trough the hole. I can't see how this should be benefical at all.
The whole purpose of the slot both under & over is to get better airflow to the underside of the car.mep wrote:Why should the flow there go around a 90° corner?
Ok, I understand.scarbs wrote:There's high pressure building up beneath the nose and the duct feeds into a relatively low pressure region created above the hump in the nose...
The little miniature wing sitting on the middle of the beam wing.strad wrote:Monkey seat??
