GoranF1
GoranF1
151
Re: Ferrari Power Unit
giantfan10 wrote:
GoranF1 wrote:Ferrari TC in Canada will not bring any more power in Q mode that what Ferrari already have(the point of FIA reliabilty updates)...but Ferrari may now be able to use it more in race modes.
EDIT:
https://twitter.com/f1talks/status/740119801415225344
What youre saying doesnt make sense...
The turbo now spinning at max RPM and a new compressor will provide more power regardless of it its qualifying or in the race....lower RPM = less boost and the previous turbo was running at less than max rpm to preserve it..im not saying there will be some earth shattering improvement but there should be improvement.
It was able to spin at max rpm before....just for a shorter period of time.
giantfan10
giantfan10
27
GoranF1 wrote:
EDIT:
I highly doubt that since the issue was vibration at normal operating RPM jamesallenonf1.com :
This will fix a problem whereby vibrations from the turbo, which is seeking to spin at very high speeds, are causing the unit to overheat. Ferrari has not been able to exploit the full potential of its unit as a result and has had to run more conservatively.
Does this mean their turbo is going over the mgu-h limit of 125,000 rpm?
470
godlameroso wrote:Does this mean their turbo is going over the mgu-h limit of 125,000 rpm?
No.
giantfan10
giantfan10
27
No they were running their turbo under the FIA mandated limit....the fix is supposed to allow them to get to that limit
The turbo upgrade is a great deal of improvement for Ferrari in the Canada race today. They could push really hard right thru the race, and fuel efficiency was not badly affected last previous times.
As we predicted during winter testing...
568
Curious that they should use a cool medium (air) in the first stage intercooler and a "warmer" medium (water) in the second stage?
NL_Fer
NL_Fer
82
gruntguru wrote:Curious that they should use a cool medium (air) in the first stage intercooler and a "warmer" medium (water) in the second stage?
Not if they pre-cool the "liquid" to subzero temperatures before the start or qualifing run and stuff the complete sidepod with dryice.
ME4ME
79
Not everything is about qualifying though..
NL_Fer
NL_Fer
82
Even in the race a air-water intercooler is ok for racing cars. Yes the liquid will warm up under boost, but has time to cool off again during coasting and braking.
Brian Coat
Brian Coat
99
I cannot see what the coolant circuit for the water-air intercooler is, in the images.
If it is downstream of the air/air, inter cooler, one assumes it is a separate circuit running at a lower temperature?
Does that make sense?
568
In fact almost everything is about speed in race trim.
sosic2121
sosic2121
I agree. what's the point of having air - air cooler at all(in this order) ?
Perhaps it's to more accurately control intake air temperature, not necessarily to get the intake charge as cold as possible but as consistent as possible. Then you have to wonder why they would in the first place.
