Mercedes AMG F1 W09 EQ Power+
OO7
OO7
171
Re: Mercedes AMG F1 W09 EQ Power+
Kalsi wrote:
13 Mar 2018, 01:18
Sorry if this was posted before but...
CircusF1 claiming W09 not only retained it`s wheelbase, but it increased instead by another 63mm taking the mercedes to a whopping 3.823mm.
SF71-H on the other hand should be 120mm longer than it`s predecessor... taking the ferrari 2018 car to 3.714mm.
Here is the source link: http://www.circusf1.com/2018/03/le-f1-2 ... 9-60mm.php
In Short:
W08 = 3,760 mm >>>>> +63mm >>>>> W09 = 3,823mm
SF70-H = ‎3,594 mm >>>>> +120mm >>>>> SF71-H = 3,714mm
Notice how W08 was still longer than this year SF71-H
Anyone can confirm?
Mercedes have claimed the wheelbase of the W09 is the same as the W08. In any event an increase of 63mm would be noticeable to the eye, especially considering how long the 2017 car was already.
cramr
cramr
Just_a_fan wrote:
13 Mar 2018, 01:28
Maritimer wrote:
13 Mar 2018, 00:17
What kind of velocity does the air coming out of the cooling exits have? Is there any advantage to having them exit over the diffuser like that? Other than simplicity.
The air will be hot and thus lower density than ambient. Although the airflow might be slower than that immediately around the openings, the temperature induced lower density might allow the same effect i.e. to reduce the pressure difference above and below the floor at the diffuser's exit. The diffuser's job is to bring the pressure of the air exiting from below the floor back to the same as the pressure around the car (ambient). By having fast air moving over the diffuser, you reduce the pressure differences between the flows above/below the floor and there is then less drag as the flows merge. Fast air is lower pressure, as is hot air. So having hot air means the same benefits as "fast air". The teams have to dump the hot air somewhere and doing it this way helps the aero performance. That's my entirely amateur "first guess". :oops:
Oh, and having hot air blow below the rear wing would give an enhanced pressure difference across the wing too - more downforce at a given speed. Although I doubt this effect is what they're chasing here.
The cooling flow is too slow and turbulent to be used for anything that's why the teams place the exit as far away from the diffuser and RW and rear brake ducts deflectors as possible because that flow is pretty much useless
Moose
Moose
52
cramr wrote:
13 Mar 2018, 08:43
Yes and no - yes, the cooling flow is basically useless, no, the placement *does* matter. Its placement can determine how much suction the aerodynamics provide to help drive air through the car's interior, which can allow them to shrink radiators etc.
atanatizante
115
Are those 2 "lips" on the second layer of Gurney flaps new?
And in addition, that air coming out of the cooling exits could help that "beam wing"? (which in fact is a fairing for rear drive axle and the lower wishbone) ...
Jesus
joeyg02
Blaze1 wrote:
13 Mar 2018, 01:52
Kalsi wrote:
13 Mar 2018, 01:18
In Short:
Anyone can confirm?
You're telling me that by pictures alone you could tell if the car was 2.5" longer? If so you need to be checked for superhuman ability. That's an inch shorter than the width of a business card.
Drafting & Design Engineer - I crave information & live in a never ending quest for answers to whatever piques my curiosity.
Joey Griffin - Owner - JG GraphX.
Lifelong Motorsport Fan from Southern Georgia, United States.
Mattchu
atanatizante wrote:
13 Mar 2018, 23:50
https://s17.postimg.org/vfw4k7mjz/2018- ... 0_-_F1.jpg
There not "lips". As you can see in the image below the top edge of the diffusor splits into 2 about 150mm into the horizontal plane, then 1 then 2 again. One [the lower inside] goes straight through to the other side while the top rises up and does the saw teeth bit behind 2 winglets [which look very upright] next to the rear crash structure..
Just on the 2 upright winglets, they must come under some pretty huge force when going at high speed and pretty much just block the air [like putting your hand out of a car window]. Would Mercedes do this so the diffuser central section doesn`t have a downspill of turbulent air?
Well, one it only works because the crash structure is causing blockage at one side, two they should turn enough air to help link the diffuser/exhaust/rear wing flows, and yes, you would imagine with that sharp edge they'd send a pair of small counter-rotating vortices down the side of the crash structure which might help extract the diffuser before they converge.
I think that's probably secondary though and the main effect is just to turn the flow hard, especially given the sawtooth element below.
PhillipM wrote:
18 Mar 2018, 16:22
You're talking about the vortex generators or the jagged surface where the crash structure and diffuser meet?
W08 Abu Dhabi vs W09 test spec.
"L" elements being the big difference.
toraabe
toraabe
RZS10
359
Kalsi wrote:
13 Mar 2018, 01:18
In Short:
Anyone can confirm?
Google translated portions of it to
"From our photos , which we will show here only partially and in low resolution, we have calculated" ...
So they won't show the pics they've supposedly used to "calculate" their results and they won't show their methodology ... i just took the side view of the merc from the article and did the good old pixel/cm thing (which i think ignores the fact that the car is turning etc and i would never claim to be precise) ... probably just clickbait bs
Or the other way round ... if those were actually 3.82m the wheels would have to be 76 pixels ... yet they're obviously bigger
Funnily enough the official F1 site claimed the opposite - that the merc had gotten shorter ...
zibby43
zibby43
613
ScrewCaptain27
577
S-duct inlet has a very rough finish:
Looks like the older version was cut out and an updated one was crudely bonded in.
Via @AlbertFabrega
- Serj Tankian
