Alpine A521
SiLo
139
Re: Alpine A521
Any good angles of the sidepods to see if they are actually smaller than other teams?
Felipe Baby!
Re: Alpine A521
radosav wrote:
25 Mar 2021, 23:37
I think people are trying to find some miracle things in desing of a car that only has purpose to be a project that will
be starting point of new brand and maybe test some things for 2022. car during this season.
You mean Design ? I think it makes sence to introduce the front compressor PU, if they really do plan to, this year to be better prepared for next.
radosav
radosav
Re: Alpine A521
diffuser wrote:
26 Mar 2021, 00:15
radosav wrote:
25 Mar 2021, 23:37
well that does make sense tbh
BassVirolla
Re: Alpine A521
Hard speculation: Could it be a twin venturi cooling? Primary flow through the sidepods, mainly for aerodinamical reasons (blowing over the diffuser) and "nozzle ducts" blowing from roll hoop to sidepod ducts, through radiators.
Re: Alpine A521
The legs tubes seem to go far down?
Re: Alpine A521
diffuser wrote:
26 Mar 2021, 02:15
If I understand Scarbs correctly, they replace the good old Renault compressor airbox (the lighter green here)
Thanks Caterham and @KevTs for the pics
So they feed the darker green compressor disc-shaped airbox (which didnt change much between 2014 and 2020), or the compressor directly, from two sides, similar to the 2016 Ferrari?
This could also explain why these odd looking ducts seem to have an air filter enclosure (purple rectangle)
@NicolasF1i
https://i.imgur.com/a9l51dm.jpg
Re: Alpine A521
Right but why did they put the lower air intake's rad so far out?
Seems like a B-team, budget, unimaginative move.
I had heard that they had been living with cooling issues last year that they needed tokens to fix. Is this what they spent their tokens on?
Re: Alpine A521
diffuser wrote:
26 Mar 2021, 08:47
That's one of the questions.
Cooling dont need tokens (unless you use special coolers like water-oil or water-water rads, But Renault do not use that kind of rads AFAIK) So teams can change 90% or 100% of their cooling for free.
And as already said they spent their tokens on the gearbox casing, at least to change the suspension mounting points.
But I never heard them saying they had cooling issues... However it could explain why they added 1001 more coolers to the car and relocated their old CCS (if Scarbs is right), with very minimal sidepod/undercut gains.
aerofoilf1
aerofoilf1
247
Re: Alpine A521
FP1 floor tests
aerofoilf1
aerofoilf1
247
Re: Alpine A521
New Halo fairing
stan_french
stan_french
Re: Alpine A521
aerofoilf1 wrote:
26 Mar 2021, 17:38
New Halo fairing
https://pbs.twimg.com/media/ExaoZB-WYAo ... name=large
Yh interesting that they didnt use it in fp2
kfrantzios
kfrantzios
46
Re: Alpine A521
more details on the new floor tested
Re: Alpine A521
A bit off topic, but are these cost cutting measures? Making these things out of (i assume)detacheable aluminum, rather than integrated carbon.
Saving money on details might be a good thing in the new era.
Owen.C93
Owen.C93
177
Re: Alpine A521
Time more than money no doubt. I'm sure the one they chose will be in carbon for the next race.
radosav
radosav
Re: Alpine A521
