Aston Martin AMR22
Re: Aston Martin AMR22
siskue2005 wrote:
14 Feb 2022, 11:06
ringo wrote:
14 Feb 2022, 01:52
This car could dow with some flow straighteners on top of the sloping sidepods. But i doubt its permitted.
Looks good so far. The concept should result in more airflow to the diffuser, But it also results in more surface drag and possibly more lift from the body.
And also higher centre of gravity
If a higher centre of gravity gives better aero, it seems that the teams go with it. The aero component is more important than a marginal CoG height change in these cars it seems.
Tzk
Tzk
36
Hoffman900 wrote:
12 Feb 2022, 18:09
Are those demo tires? I thought they had to run treaded tires for filming days?
They run special 'filming day' tires, but those don't have to be threaded.
ajprice
ajprice
21
I understand how ground effect works between the car and the ground. Can someone explain like I'm 5 how an air channel between the bodywork and the floor works? Wouldn't any effect that has on downforce or airflow or whatever be like trying to lift yourself up by your bootlaces?
the EDGE
the EDGE
68
ajprice wrote:
14 Feb 2022, 12:58
It’s like when you suck air out of a plastics bottle, both sides want to suck together
The air from the inlet is compressed then expanded in the tunnel which create a low pressure sucking the air in
As their is no bottom on the tunnel, the track acts like the other side of the bottle and the 2 are sucked together
Henri
Henri
-6
Lets hope is faster than the way it looks
pantherxxx
pantherxxx
This can be a championship winning car. The team that uses the venturi effect the most effectively will probably win, and the double floor + gills may be the way to do it.
Zynerji
111
pantherxxx wrote:
14 Feb 2022, 14:55
I think the one that balances the high speed/low speed downforce generation best will win.
Emag
Emag
109
pantherxxx wrote:
14 Feb 2022, 14:55
I seriously doubt the other teams missed such a straightforward implementation of these rules. I am almost certain it has been considered by all of the teams actually, but I guess so far, AM has been the only one brave enough to go for it.
Developer of F1InsightsHub
Pandamasque
ajprice wrote:
14 Feb 2022, 12:58
In simple terms, the way I understand it, the flow above the underfloor tunnel entrance and, especially, exit helps speeding up the flow in the tunnel itself.
Emag wrote:
14 Feb 2022, 14:59
pantherxxx wrote:
14 Feb 2022, 14:55
I bet all of the concepts work well to an extent. The question is which team got the CFD/tunnel vs real world correlation better. Reaction of the different concepts to bumps and curbs, changing ride height, yaw, crosswinds may render some of these concepts a total failure compared to others. Even if they all have similar peak performance, some may have a far broader "window" as far as setups and conditions are concerned.
Emag
Emag
109
Pandamasque wrote:
14 Feb 2022, 14:59
ajprice wrote:
14 Feb 2022, 12:58
Emag wrote:
14 Feb 2022, 14:59
pantherxxx wrote:
14 Feb 2022, 14:55
Thats the thing. You need consistency. If I remember correctly, the 2018 McLaren was not a bad car ... on a straight line. They miscalculated their design, and when the wheels were turning they suffered from flow separation and lost downforce through the corners when it was needed the most.
So you are right. There are many variables to consider. It could go wrong for 1000 different reasons even if the concept itself makes sense.
I see two holes behind the bib looking from the front view. Does anyone else see it?
PlatinumZealot wrote:
14 Feb 2022, 15:33
Picture please... Thx
basti313
basti313
Just_a_fan wrote:
14 Feb 2022, 11:11
siskue2005 wrote:
14 Feb 2022, 11:06
ringo wrote:
14 Feb 2022, 01:52
I guess this is the same discussion as with the harder suspension to help the aero.
In the end a real driver needs to drive the car. I fear that it will be much harder to drive if you trade a higher CoG vs. some aero performance. So this is unfortunately something where they can not even do an analysis on theoretical lap times, but this is a comparison that really will only show on track what is right or not.
Don`t russel the hamster!
basti313 wrote:
14 Feb 2022, 16:23
Just_a_fan wrote:
14 Feb 2022, 11:11
siskue2005 wrote:
14 Feb 2022, 11:06
Racing drivers are relatively simple creatures to please - you just give them a faster car. They'll live with the compromise if it means they have more chance on track.
pantherxxx
pantherxxx
Emag wrote:
14 Feb 2022, 14:59
pantherxxx wrote:
14 Feb 2022, 14:55
We don't know. Red Bull, Mercedes and Ferrari haven't even released their real cars yet, it's possible that they will have a similar solution.
