McL ─ AMR ∖ RB \
Also note RB have the thinnest arms which has been apparent since last year.
It does look extremely narrow.AR3-GP wrote: ↑30 Mar 2023, 15:58RB19 rear seems narrower than SF23 but perhaps it's an optical illusion because of the cannon outlets on the RB.F1NAC wrote: ↑30 Mar 2023, 15:38Looking at the single pillar construction. Ferrari's pillar seems a bit chunkier than RB19. Possibly to tackle with wobblyness.
https://pbs.twimg.com/media/Fscf5wzaQAE ... ame=medium
https://pbs.twimg.com/media/FscwBaSaYAE ... name=large
The rearmost part definitely looks very narrow.
Illusion I would say, due to cannon vent. Look at the width of the diffuser, it almost appears bigger on Ferrari. Good point of reference is also the rear wing pylon mounting, exhaust is fixed diameter and so is the pylon arch basically.
And the trade-off?Farnborough wrote: ↑31 Mar 2023, 22:47Quite a difference isn't there, in front arm geometry.
The anti dive would appear to keep the front of the chassis "platform" within a very tight range judging from the images of that type under varying load.
Unlike pure spring rate to do similar, this allows more malleable setting of the torsion spring rate to be used.
Dramatically reduced pitch seems vital in keeping floor front (strikes, outwash etc) in more planar orientation to pull out consistency in peak performance.
I hear there is a bidding war for the originals
Notice how the drs for the redbull is pulled colinearly with the hydraulic piston?AR3-GP wrote: ↑30 Mar 2023, 15:58RB19 rear seems narrower than SF23 but perhaps it's an optical illusion because of the cannon outlets on the RB.F1NAC wrote: ↑30 Mar 2023, 15:38Looking at the single pillar construction. Ferrari's pillar seems a bit chunkier than RB19. Possibly to tackle with wobblyness.
The anti-dive geometry is determined by the intersection of the upper and lower wishbone inboard pivot axes. The location of the instantaneous center (IC, the white dot in the image below) relative to the CG height is used to determine the % anti-dive.vorticism wrote: ↑31 Mar 2023, 21:51Cropped some images together. Variations on the A-arm inclination from flat to highly inclined.
McL ─ AMR ∖ RB \
https://i.postimg.cc/Kzg56DXZ/Screen-Sh ... -14-PM.png
https://www.racefans.net/wp-content/upl ... 5-12-9.jpg
https://www.racefans.net/wp-content/upl ... -09-10.jpg
https://www.racefans.net/wp-content/upl ... -07-12.jpg
I'm pretty sure it is narrower.AR3-GP wrote: ↑30 Mar 2023, 15:58RB19 rear seems narrower than SF23 but perhaps it's an optical illusion because of the cannon outlets on the RB.F1NAC wrote: ↑30 Mar 2023, 15:38Looking at the single pillar construction. Ferrari's pillar seems a bit chunkier than RB19. Possibly to tackle with wobblyness.
The Alfa is begging for slides.mclaren111 wrote: ↑04 Apr 2023, 11:03https://i0.wp.com/www.salastamparacing. ... .jpg?ssl=1
Australia...
