except from the possible "on track action" being far better, what do you mean by that?Metar wrote:Straight-line speed isn't the only field where MotoGP appears superior at the moment.
I read Peter Sauber called movable rare wings 'insane idea' for the very same reasonShaddock wrote:If ever the rear wing servo fails and the wing does not revert to it’s high DF setting as the car enters the braking zone then the car will sail straight on into the scenery.
Actually, I'd have to take that statement back. They use spec tyres this season, and engine-development is now open in F1 as well... The 17kRPM-and-onwards 800cc engines are quite a feast for the ears. In fact, there are now quite a few similarities. Both use a spec tyre, no refueling and unlimited engines restricted by fuel-consumption and one-race-reliability alone. One could claim hiding behind the windshield and rising as an airbrake is active aero, too.Ogami musashi wrote:except from the possible "on track action" being far better, what do you mean by that?
Back in 2004 even Michael Schumacher complained about fysical problems due to the high cornering speeds. From a safety point of view the cornerings speeds may well become too high.Ogami musashi wrote:I would love them to be faster like in 2004 yes.
Top speed would be faster and that would be great because nowadays moto gp are faster in straight line.
The cornering speeds wont increase next year by all that much as peak downforce levels will not increase by any great margin (and you have the min weight limit increase too). The problem with the 2004 F1 cars is that they were ridiculously fast in both straight lines AND even faster in the corners. It was a combination never seen before - it was the apex, if you will. Next year we'll see this year's cornering speeds (well, apart from the drag-restricted corners, such as 130R or Eau Rouge or Bridge...well, scrap the last onePingguest wrote:Back in 2004 even Michael Schumacher complained about fysical problems due to the high cornering speeds. From a safety point of view the cornerings speeds may well become too high.Ogami musashi wrote:I would love them to be faster like in 2004 yes.
Automatic adjustmens would just be another driver aid. I don't think that sort of technology should be in Formula 1.WhiteBlue wrote:I agree that variable wing geometry can be a concern. Peter Sauber once had to pull his cars out of the Brazil GP because rear wings were flexing too much and broke. That has probably influenced his position on movable rear wings.
Having said that I also agree with the view that redundant safety systems have to be implemented to make this as safe as the systems in commercial airplanes. That should be the target.
The other aspect mentioned already by Ogami is the manual activation of the adjustable stuff. I believe this is currently going over the top. The drivers have to push buttons for Rear KERS, Front KERS, Front Wings , Rear wings and they also need to drive the cars. I feel it is getting a bit too much with this. Some systems should be automated perhaps the wings as Ogami suggested.
So, is automatic ignition timing adjustment a driver aid? Should we have manual timing advancement and retard in the cars?Pingguest wrote:Automatic adjustmens would just be another driver aid. I don't think that sort of technology should be in Formula 1.WhiteBlue wrote:I agree that variable wing geometry can be a concern. Peter Sauber once had to pull his cars out of the Brazil GP because rear wings were flexing too much and broke. That has probably influenced his position on movable rear wings.
