http://img14.imagevenue.com/img.php?ima ... _582lo.jpgGiblet wrote:I just noticed the small windscreen on the car.
I have not seen (noticed anyways) a windscreen for years.
I'm sorry then, I didn't knew that it was just sensor. I thought it was hole.madly wrote:I'm not sure if R30 floor has changed in Jarez. Korzeniow said that, but I don't see any changes on the photos, nor any other info about floor upgrade except this forum.
man, can't draw any conclusion from this picture; the engine cover is hardly seen complete!!!spaman wrote:Has the car a new engine cover? I think the back end looks much tighter on this picture.
Nose looks different either - or is it just the angle of the picture?
Is it just me? Isn't the driver sitting so high that nearly half the helmet is above the back support and most probably messing up the whole airflow? It looks like he should be at least 5cm lower.korzeniow wrote:New barge boards, moved to front.
