The Beam wing is influenced by the same on the RB9! Newey has so many admirers in rival teams. They can't help but to try his solutions.emmepi27 wrote:New beam wing
http://img3.auto-motor-und-sport.de/Mer ... 716380.jpg
In a way you are correct in saying that it helps off throttle blowing. However you are totally wrong when it comes to how. It does not "collect" exhaust gasses on throttle and release them off throttle. It simply acoustically tunes the exhaust to have more mass flow going through at low to no load on the engine. Either that or it is widely known that they can also be used to tune the exhaust flow track for track.turbof1 wrote:http://www.formula1.com/news/technical/ ... 5/919.htmlmarcush. wrote:surely not the volume is too small to provide a functionality like that .A Helmholtz device is there to tune the behaviour of the engine induction/exhaustsystem system at a specific rpm /load combo .turbof1 wrote:It collect some exhaust fumes and releases it when the driver goes off throttle, recovering a tiny bit of of throttle blowing.
One can assume the chosen exhaust does have a peak or a dip in performance at some point of the usable power range affecting car performance /driveability ..it is a ways of tuning the exhaust pulses .
With the Helmholtz setup you can get rid of the dip or a unwanted peak -it is crude but effective -but only at a certain point of the useable range of the engine ..but as variable intake length and exhaust are outlawed you use what is allowed...
almost vertical aoa on that front wingk.ko100v wrote:![]()
Different thermal cameras on the wings...oddstefan_ wrote:Italy 2013 - Friday (06.09.2013)
http://i.imgur.com/gDcTd5Q.jpg
http://i.imgur.com/2Ttg3vC.jpg
Nico ran the high downforce front wing with DRD i think, the "old" camera mount is on the Monza spec wing.NewtonMeter wrote:Different thermal cameras on the wings...oddstefan_ wrote:Italy 2013 - Friday (06.09.2013)
