Red Schneider wrote:I mean that their front wing designs are probably in the pipeline. It's on its way, so I wouldn't panic at this stage.
Now that I think about it, you might even say that detailed front wing design comes a little bit second because (apart from increasing downforce at the front end) you're asking yourself, 'how can I shape the airflow so that it goes over and around the sidepods the right way to the back of the car?' In other words you need a working concept for the sidepods and rear before you can decide how the front wing can contribute to guiding the airflow.
It's a bit simplistic and just a guess, but it makes some sense to me, and it also fits the trend of teams launching with old front wings.
Well, I would probably work otherwise. I would firstly start with the FW and determine how much clean air I could send, then, the sidepods, trying to make them the less obtrusive possible. But that was if I was starting from scratch.
I understant that they are improving a base that was deployed last year. And thinking so, I can understand that, even for comparision with last year car, to create a measurement baseline to be sure that they've achieved correlation between CFD and WT figures with real life, that they have to work by steps. And with that in mind, I would leave the FW for a later moment, a moment when I would have those CFD and WT figures corrected or certified so I could be sure that the FW I developed was going to achieve whatever I was trying to achieve.
In that way, then I absolutely agree with you
