Alpine A521
RedNEO
40
Re: Alpine A521
kfrantzios wrote:
26 Mar 2021, 19:01
more details on the new floor tested
https://pbs.twimg.com/media/Exa2rY7XMAY ... ame=medium
Team is working hard. Keep it up 💪
Re: Alpine A521
Blackout wrote:
25 Mar 2021, 21:15
This is very possible too : P
Scarbs is missing a cooler. There is a wide one infront of the intake pipe but its hidden by the ducting.
radosav
radosav
Re: Alpine A521
alonso after fp2 said that they are looking for balance, they have data from testing and is sure they will do better tomorow , and they have something in pocket
aerofoilf1
aerofoilf1
247
Re: Alpine A521
Cooling outlets...V3 in FP1. V1 was the other, smaller option from testing. V2 was run in P2.
Re: Alpine A521
PlatinumZealot wrote:
26 Mar 2021, 22:41
In front of the intake pipe?
Re: Alpine A521
Blackout wrote:
27 Mar 2021, 08:59
26 Mar 2021, 22:41
Look at the plumbing an ducting more discerningly. The big old space was not left empty, and the coolers on the back of the intake alone didn't justify the width of the cover. So basically, the same wide cooler from last year is still in roughly the same position, but ducted a bit differently. (in two left-right halves)
RedNEO
40
Re: Alpine A521
@NicolasF1i
Still a lot of question marks under the skin of the Alpine
#F1 | #BahrainGP | #TechF1
zack!
zack!
Re: Alpine A521
Look like the driving wheel is in "verbose mode", no ? I never seen this kind of feedback info, someone is able to confirm and decipher that ?
zack!
zack!
Re: Alpine A521
"brake shape 2", "brake shape 3", brake balance -2%", "brake shape 3", brake balance 0%", "brake shape 2", "ENTR 6", "TORQ 9", "ENTR 8", "TORQ 10", "ENTR 6", "TORQ 9", "RCHG" (recharge on).
Is that a programmable map, or a manual activation ? Thx in advance for the answer...
zack!
zack!
Re: Alpine A521
ENTR is a DIFF setting...
Is those commands only "manual" activation by Alonso ?
JPower
JPower
43
Re: Alpine A521
zack! wrote:
27 Mar 2021, 21:23
Its most likely a preset on the back of the wheel. I've seen onboards for Renault over the past few years and every driver had similar adjustments to what you're seeing with Alonso.
zack!
zack!
Re: Alpine A521
thx, what is TORQ command ? (MGU-K strenght ? for energy recovery -braking- may be ?)
Re: Alpine A521
zack! wrote:
27 Mar 2021, 21:47
PowerandtheGlory
PowerandtheGlory
Re: Alpine A521
kfrantzios wrote:
26 Mar 2021, 19:01
Some teams are struggling with sealing the floor and managing air around the exclusion zone before the tyre. High rake is less affected. This area will be a hot-bed of development for a while as team try to figure out the solution.. for now.. look at Ferrari and alphaT for pointers!
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
Re: Alpine A521
27 Mar 2021, 14:20
Blackout wrote:
27 Mar 2021, 08:59
26 Mar 2021, 22:41
So you partly subscribe to Scarbs point of view, but you add that the old CCS (pink here) is still there, but in a different shape and size...
It's an interesting point of view but it adds even more questions and mystery* :P
To me, the green ducts are the reason that justifies the increase of the rollhoop width (if Scarbs is right when he says those ducts feed the compressor, not the new red CCS) and that the compressor duct has been split to let a longer CCS duct pass and go to the red rad.
(Original photo and comparison from @NicolasF1i
The question is, why would this team make these changes and even add more radiators to the center of the car AND keep the sidepod cooling basically unchanged.
The sidepod undercut is roughly the same as 2019 and the sidepod cooling systems also look similar to 2019 and 2020 in layout and size.
They still have a relatively big intercooler + an engine rad in each sidepod (a water rad in the right hand sidepod and an oil rad in the other AFAIK)...
