Or Euro 10 standard
http://www.croll.com/air_library/brochu ... ubbers.pdf
http://www.croll.com/air_library/techni ... ticle1.php
Andrew
Actually the power of a Vacuum is rather poor. Well you can't really go below a pressure of less than 0. This is one of the reasons intake valves are always bigger than exhaust valves.Feliks wrote:Amazing power is the power vacuum. We know this for a long time .. Now, it will work for us. and only think with pity, which can do a traditional windmill with a diameter of 0, 5 meter ...
Yes, apparently, it is weak because it's "only" a maximum pressure of 1 atmosphere ... I also, for example, the difference in pressure between the historically high and low atmospheric pressure is low, but the hurricane has a good power ...rscsr wrote:Feliks wrote:Amazing power is the power vacuum. We know this for a long time .. Now, it will work for us. and only think with pity, which can do a traditional windmill with a diameter of 0, 5 meter ...
What is this system name'? Is it called "exhaust scrubber"?Feliks wrote:The end of such passive sports engine exhausts:
http://www.new4stroke.com/wydech.jpg
These old-style sausages only reach about 0.2 atmosphere vacuum. A new way of sucking exhaust ejector via a venturi is able to achieve 0.8 atmosphere vacuum. We can add it to the engine power of about 30% if the well will adjust camshaft....
As a result of additional air into the exhaust also added clarity will improve as a result of combustion gases....
http://www.new4stroke.com/Vacuum.jpg
The company has also achievements in the treatment of gases, both solid particles and NOx ..
For large trucks and marine engines, you can give the water cleaner exhaust. Then, no longer see the black smoke from the exhaust pipe truck. A vacuum is created and injected via a closed loop water will improve engine efficiency as a significant ..
http://www.new4stroke.com/water.jpg
Andrew
Yes, very accurately you call it .. This makes it easier to understand the essence of the organization ..shelly wrote:What is this system name'? Is it called "exhaust scrubber"?Feliks wrote:The end of such passive sports engine exhausts:
Andrew
