About CAEdevice: same classification of the previous race, but a bit disappointing this time: I had problems with the flows under and over the diffuser. Hope to solve them for Monza.
PS: My car was at first place in the two fast corners
Yes, it will be difficult because many cars are quite near now, but your car seems to adapt easily to fast tracks (even if I didn't think that Magny Cours was a low downforce circuit).variante wrote:Thanks Matteo.
It will be hard to win at Monza, though...
Variante's car worked well, but CSR's car with more downforce (and the attendent drag) was very close.... a car having a Cd.A of 1.1 and a -Cl.A of 2.65 would've been quicker than Variante..... easier said than done, I know, but we have seen cars in the Khamsin challenge with aero coefficients not far off those figures in last year's competition...CAEdevice wrote:(even if I didn't think that Magny Cours was a low downforce circuit).
Hi Luke, I appreciate the visual: even if there is a discalimer, it seems that speed values are reasonable true.astracrazy wrote:Lastly I haven't had any feedback from the race visual, do you all use if first? Did you like it? Would you want anything changed?
Yes, exaclty the solution that worked well in my case.astracrazy wrote: A solution for both of you could be to cut down the area the you use the plug in? i.e instead of covering one big area, split it into 3-4 sections?
It is worth remembering that Cd.A is a function of the car design, not a direct function of the track design; i.e. if Cd.A values were higher than expected at Monza last year then there is only one reason for it: the car's that were submitted had high Cd.A values. I think that we are only just seeing that everyone has previously been working with Cd.A values that were too high; as per graph above, we should be aiming to see Cd.A values in the region of 0.8 to 1.2, maybe even lower, whereas previously we were seeing Cd.A values of the submitted cars in the range 1.2 to 1.5.CAEdevice (On Variante's thread) wrote:Sure, but I was looking at the values of Cd.A of Monza 2013, and they are higher than I would expect (also considering a 20% more drag for the diffrent rules).
