Red Bull RB12 TAG-Heuer
flmkane
flmkane
Re: Red Bull RB12 TAG-Heuer
noname wrote:
flmkane wrote:Guess what's cheaper and gives better results. TESTING!!!!
On top of that simulator provides very well controlled environment. Test chambers/cells/simulators are being used everywhere, why F1 should rely solely on such an old fashioned tool as field testing?
Answer: because testing is faster. Case in point, McLaren Honda, Ferrari posted 2008 and Red Bull 2014-2015
http://en.f1i.com/magazine/57620-techni ... aco.html/2
Monaco always brings the goods lol.
I doubt that. For testing you need to bring a whole crew, trucks etc. etc. Cars have to be built before running and you are spending a lot of time in the pits. In a simulator you can just get in and go
SR71
I am not that certain.
To do track testing you need to rent the track, send the cars, parts, equipment and people there, to properly evaluate components after testing you have to ship them back, risk in case something will fail is much lower, etc. Unless the team has a track next to the factory simulator can simplify (and thus make cheaper) whole logistic behind.
Doesn't field testing also require physical parts? If you wanted to test 10 Front wings which take 6 weeks to build each that's just ridiculous.
Simulating those is a few mouse clicks. If you know your simulator is very well correlated you only need a handful of field tests to verify the best results.
No way field testing comes back as we previously knew it.
rscsr
51
The simulation still needs a significant amount of time. According to TMG a change of a front wing needs about a day for results. But simulation is usually still significantly cheaper and more useful than field testing.
carisi2k
27
That is just a titanium block at the front. The sparks coming from underneath the car are created by that. There isn't anything allowed to be developed in that area.
seezung
seezung
56
New spec rw:
ME4ME
79
Looks like the old one to me, with the long vertical slot in the end plate.
It's a "new" one, or better yet first used this season. The endplate has the leading edge slot stretched almost completely along the length of the leading edge, and has less louvres. The leading edge of the mainplane aerofoil is also carefully sculpted.
EDIT: Sorry, it's indeed not new. It's the same like the one in Russia, albeit still with differences. A bit of a hybrid between the Monaco and the Russia spec.
Albrodpul
Albrodpul
Not new. Bahrain spec:
Juzh
161
It is a lower downforce setup, but does not seem over the top skinny.
It is indeed interesting they are taking the Bahrain spec wing. Bahrain is considered to be more of a medium downforce circuit, while Canada belongs in the lower range. Normally you'd see atleast a wing with less AoA.
It shows confidence in the increased horsepower and increased efficiency to compensate for the extra drag and fuel consumption. We might see Red Bull run more downforce on all circuits from now.
atlantis
atlantis
21
1,5cm shorter new nose for RedBull in Canada... will it be difficult to spot the difference from the old one? :)
https://twitter.com/F1_LAT/status/741001813550305281
GoranF1
GoranF1
151
