2026 Aerodynamic & Chassis Regulations
mzso
mzso
65
Re: 2026 Aerodynamic & Chassis Regulations
JordanMugen wrote:
07 Jun 2024, 22:54
mzso wrote:
07 Jun 2024, 12:42
They should define a maximum length
There is! 3400mm plus the specified overhangs.
You suppose that should be 3000mm or less?
Interestingly F2 car length is 5220mm with wheelbase 3135mm.
That's not technically a definition of maximum length. But what value can be calculated? I guess it's still atrociously long.
I would say 4,5m (or less) total length. And let them do whatever they want with wheelbase.
467
Vanja #66 wrote:
08 Jun 2024, 14:01
wuzak wrote:
08 Jun 2024, 13:24
48% thermal efficiency gives an ICE output of 400kW/536hp.
The MGUK output is reduced with speed above 290kph.
Total power
at 290kph = 750kW/1,006hp
at 300 kph = 700kW/939hp
at 320kph = 600kW/805hp
at 340kph = 500kW/671hp
at 345kph = 400kW/536hp.
In override mode, the full MGUK power of 350kW is maintained to 337.5kph, so total PU output of 750kW/1,006hp, falling a total of 400kW/536hp at 355kph.
So this means in a regular lap you have no e-deployment above 345 kmh and rely solely on ICE? Or is even the ICE limited to 400kW output and you can (must?) send the rest to MGU and batteries?
Yes, regular deployment.
The ICE is limited by the fuel flow, maximum 3,000MJ/h.
48% efficiency = 400kW
50% efficiency = 417kW
52% efficiency = 433kW
46% efficiency = 383kW
So the ICE output depends on the efficiency that the manufacturers can get.
400kW is oftend cited by the FIA, so must be what they roughly expect.
FW17
169
wuzak wrote:
08 Jun 2024, 17:43
Vanja #66 wrote:
08 Jun 2024, 14:01
wuzak wrote:
08 Jun 2024, 13:24
Total power
Were is this much touted 50:50 split?
Jambier
The weight reduction is also a joke.
It reminds me of early 2014 and max RPM set to 15000 per regulation.
But engines actually reached 11000 not more
It will be same joke with the weight in 2026.
I don’t like the active aero but the really pain is the engine regulation.
E fuel is good idea but the massive hybrid is ridiculous, I even this this as outdated
10 years ago why not but now…
Jambier wrote:
08 Jun 2024, 21:12
Isn't the rpm different to the rpm maximum because the engines produce more power at these rpm ranges at this fuel flow so there's no reason to go higher?
Whereas teams will always find huge benefits in cutting weight to the new limit, even moreso under the aero development-limited era that we're in
TeamKoolGreen
TeamKoolGreen
-5
The first iteration of the 26 had matching wing. And not some Nascar COT wing thrown on. The wing looks like a step backwards. No continuety.
JordanMugen
85
Dunlay wrote:
08 Jun 2024, 10:24
I still don't understand why they went with 18 inch wheels.
Similar rim size and overall diameter to LMP1/LMH/GTP and LMP2. Not that Pirelli make LMP1 tyres AFAIK.
FW17 wrote:
08 Jun 2024, 02:58
I don't see these ugly 18 inch wheels bringing anything positive to F1
I don't think they look ugly, LMH cars like the Toyota GR Super Sport Concept look cool with their 18" wheels without their bodywork on.
TeamKoolGreen
TeamKoolGreen
-5
Jambier wrote:
08 Jun 2024, 21:12
I guess we will have drivers stripping the paint off their helmets to save weight
bananapeel23
mzso wrote:
08 Jun 2024, 17:17
JordanMugen wrote:
07 Jun 2024, 22:54
mzso wrote:
07 Jun 2024, 12:42
You can't squeeze a hybrid powertrain into those dimensions while retaining modern safety standards. F1 cars are doomed to remain big. 2016 dimensions are likely as small as we can go, but those car sizes aren't viable with the disgustingly underpowered 2026 powertrains.
I seriously doubt that the 2026 engines will last very long in their current form. Either they seriously increase the energy flow for 2027 or they switch regs entirely for 2028. The 2026 cars will be a complete joke.
mzso
mzso
65
bananapeel23 wrote:
08 Jun 2024, 23:41
mzso wrote:
08 Jun 2024, 17:17
JordanMugen wrote:
07 Jun 2024, 22:54
Nonsense. It's entirely possible. Cars don't need to completely taper away a the back. And noses and rear crash structures can be thickened if necessary.
642
08 Jun 2024, 21:16
Jambier wrote:
08 Jun 2024, 21:12
... It reminds me of early 2014 and max RPM set to 15000 per regulation.
But engines actually reached 11000 not more .....
Isn't the rpm different to the rpm maximum because the engines produce more power at these rpm ranges at this fuel flow so there's no reason to go higher?......
at the stated 2026 fuel rate 15000 rpm is matched to natural aspiration (in Otto cycle engines)
nothing says the max fuel rate must be developed at 10500 rpm
and btw some 1968 F1 cars had active aerodynamics (until after the Spanish GP fatalities)
well I'm bored
mzso
mzso
65
bananapeel23 wrote:
08 Jun 2024, 23:41
Also, more advanced composites can be used for weight saving, if made possible by regulation and budget allowances. Such as changing the carbon fiber to something a lot stronger.
The power units are artificially heavy, as well are the batteries. I remember metal matrix composites are explicitly banned, and pretty much only steel is allowed in the ICE.
The battery also has a large minimum weight and pointless road safety restrictions.
mzso
mzso
65
bananapeel23 wrote:
08 Jun 2024, 23:41
Last time the engine regs were up for change, they barely changed anything. I doubt they'll quickly change the new ones either. Maybe they'll slightly increase the flow rate.
OnEcRiTiCaL
OnEcRiTiCaL
08 Jun 2024, 21:16
Jambier wrote:
08 Jun 2024, 21:12
Rpm limited because of cost limitation. Design a higher rpm engine and still make with it few races is would cost to much to make it reliable.
bananapeel23
mzso wrote:
09 Jun 2024, 12:02
bananapeel23 wrote:
08 Jun 2024, 23:41
Well yes, you can shed a bunch of weight, but to do that you would need to use the unreasonably expensive exotic materials of the 2000s. They are so disgustingly expensive that they just can't be used within the cost cap.
Now, I'm not at all a fan of the cost cap, but if F1 has decided to use the cost cap, then exotic materials are out of the question.
