Ferrari SF-24 speculation
KimiRai
KimiRai
258
Re: Ferrari SF-24 speculation
05 Feb 2024, 00:14
scuderiabrandon wrote:
04 Feb 2024, 22:12
jambuka wrote:
04 Feb 2024, 18:46
Better tire deg observed on SF-23 and F1-75 at Barcelona tire tests. this was due to further improvement to hybrid power management.
I mean the deg has been good for a while now, some stints we were matching RB's on the softer compounds in the latter stages of the season. Pace dropped off when the compounds got harder. Which also dismisses the ridiculous idea that Ferrari prioritize setups for qualifying.
I'm not saying Ferrari priotirize setups for qualifying, but qualifying is run on the softer tires. Coincidence, we don't know.
The fact that Ferrari just randomly stopped destroying their tires like butter in the middle of the season with no significant developments suggest it was a setup issue from the beginning. Imagine someone found the wrong value had been entered somewhere and then corrected it
Wasn't there some change in electrical mapping to treat the rear tyres better?
scuderiabrandon
103
05 Feb 2024, 00:14
04 Feb 2024, 22:12
jambuka wrote:
04 Feb 2024, 18:46
There was an aero overall that started in Spain through to Japan. They made mid season deployment strategy changes to better treat the rear tyres and there was a mid season tyre changes. Ferrari also fixed major balance issues which they realized in Zandvoort, so setup changes aswell.
I don't think it was a single factor that caused deg issues.
dialtone
dialtone
121
05 Feb 2024, 00:27
05 Feb 2024, 00:14
04 Feb 2024, 22:12
Yeah, not sure what AR3-GP is on about. Ferrari made several changes to the floor, and Japan was the last update after which much of the tire issue was gone as well as unpredictability of the car mid corner.
CouncilorIrissa
CouncilorIrissa
Just how borked exactly was power delivery at the start of last season? It is the second time we hear of improvements coming from new PU mappings.
KimiRai
KimiRai
258
Under the leadership of David George, who came to Ferrari from Red Bull last year, the power/torque distribution at corner exit and the speed/power balance on the straights have been improved.
The positive effect of this may be less wear on the tires. This is good news not only for Ferrari but also for customer teams.
Xyz22
Xyz22
123
jambuka wrote:
04 Feb 2024, 18:46
To be noted that the SF 23 was run on 2025 proto tyres.
Xyz22 wrote:
05 Feb 2024, 11:45
This and the fact it should be prohibited for teams to use different electronics and software (more importantly) from what was used in races in the respective year does not inspire much confidence in authenticity of these reports. Having more data is always preferred and will be put to good use, both on tyres and other details, but anything more than that is likely pure speculation and click baiting.
AeroGimli.x
christian.falavena
Some images taken by the Sky Italy documentary about the Scuderia.
I fount interesting the CFD of the F1-75 (not properly the F1-75, maybe an evaluation of possible improvements, it's an hybrid between SF23 and F1-75)
scuderiabrandon
103
christian.falavena wrote:
05 Feb 2024, 16:11
https://postimg.cc/sGpmPTzR
https://postimg.cc/1gkDWDJR
https://postimg.cc/Z9BrFwPD
https://postimg.cc/PCFWwgDw
Oh wow. Where's this from.
The CFD is done on the SF-23 before the changes.
The CAD model is the F1-75
christian.falavena
05 Feb 2024, 16:24
05 Feb 2024, 16:11
Not sure it is properly the SF23. The cooling louvers were not on the engine cover...
It is properly the sf-23. Just like this, no?
scuderiabrandon
103
05 Feb 2024, 17:18
05 Feb 2024, 16:24
05 Feb 2024, 16:11
I have been informed that IDRA is a die casting company, not sure why there seems to be wat looks like to be some sort of pressure plot overlayed.
christian.falavena
05 Feb 2024, 17:43
05 Feb 2024, 17:18
05 Feb 2024, 16:24
There are various companies called Idra. Maybe it's something related with this https://idrasimulation.com/
christian.falavena
05 Feb 2024, 17:40
https://i.imgur.com/LDsqmva.jpeg
That's the F1-75. And it's not the car in the image, look at the front nose and sidepod shape
05 Feb 2024, 18:09
05 Feb 2024, 17:40
OK :mrgreen: true. But this is definitely the sf-23 with louvres on the engine cover
