Considering that they were re allocating the new spec wings constantly over the weekend to address availability issues it doesn't come as such a big surprise that it wasn't simply given back to Mark Webber. The team has taken the blame for the failure of the other wing on Vettel's car. So here we are having one tested wing and two cars for it to go on.mcdenife wrote:So let me get this straight, you have a new component on each car. It breaks on A's car and a fault is found presumably. So it is taken off B's car to check it doesnt have similar fault. The part is found to not have the same fault but rather than put back on the B's car you give to A because of the new policy, just made up by way, that he is ahead in the championship and some convoluted allocations argument. And you still find B's anger and reaction strange?WhiteBlue wrote:The wing was actually taken away after P3 to be nondestructively tested following the failure of the other wing on Seb's car. It should have been pretty easy for Pilbeam/Webber to confirm with factory sources that indeed this test was carried out. I don't see that this wing had to re allocated after the test to Webber.
I have said it several times that Mark may have had an acceptable grievance until the thing was explained to him between 3 and 6 pm on Saturday. The facts didn't change and he admitted yesterday that he was fully informed by then. He still choose to continue making a big fuss for his very own reasons. I call this immature or malevolent whichever you think fits the situation better. As MW is a fairly experienced F1 driver the immaturity option should be pretty much out of consideration. So his apparent motive was probably his wish to punish Horner and play mind games with young Vettel.
