saviour stivala
saviour stivala
The standardized six M12 studs mounting pattern of engine to survival cell and six M12 studs mounting pattern of gearbox to engine has been enforced at least from 2014. So if that gearbox shows four mounting studs it belongs to an era from before the gearbox to engine mountings were standardized.
aleks_ader
90
Yeah also 2015 they had 6 studs. Just the middle ones are just "holes" and the stud is probbably on the ICE.
They must add subassembly to "justify" the 6 studs rule. Ferrari in 2016 add Mercedes style casette gearbox.
zibby43
zibby43
Jozsusz
Jozsusz
-3
Guys, I have a question.
Did Ferrari want back in 2010-2011 the introduction of hybrid engines or they just voted for the V6 hybrid as it was the "minor worst" for them?
Dr. Acula
Dr. Acula
46
Jozsusz wrote:
16 May 2019, 17:17
I'm not sure what you mean with "want back" but i think you mean if Ferrari were very keen to get the V6 Turbo hybrids. Well, if i recall it correctly Ferrari wasn't against the more complex hybrid system compared to what they had back then. But what they didn't wanted was an I4 Turbo Hybrid, which was what Renault suggested originally. Ferrari wanted a V-engine.
From an engineering standpoint the V6 is clearly the better choice for a car with a monocoque because a V-engine can be used as a structural element quite easily where an straight-engine would need extensive structural reinforcement or a subframe to mount the rear suspension.
hurril
hurril
This is mildly interesting:
https://www.youtube.com/watch?v=JkCZAzZ ... gs=pl%2Cwn
Has a bar-figure that I wonder if it's the intake manifold pressure showing.
Dr. Acula
Dr. Acula
46
hurril wrote:
22 May 2019, 09:45
I don't think so. Why would you need over 4 bar manifold pressure while standing in the box and the engine idling? My guess would be oil pressure.
saviour stivala
saviour stivala
while a car is standing in the box with engine running the engine will be running as near its idle RPM as possible, who needs 4 bar boost pushing against partially open throttles?
569
There's an echo in here.
Jolle
Jolle
133
Dr. Acula wrote:
22 May 2019, 10:49
hurril wrote:
22 May 2019, 09:45
for a driver intake pressures are not really interesting, but tire pressures are!
Jolle
Jolle
133
Dr. Acula wrote:
17 May 2019, 09:20
Jozsusz wrote:
16 May 2019, 17:17
Not just for an engineering standpoint, a small subframe would of handled that, plus if everybody had the same problem there wouldn't be a problem. It has more to do with marketing. A Ferrari with an inline four is out of the question. While Mercedes and Renault saw potential, road cars with a 1.6 turbo are kinda the sweet spot for a hot hatch, not the case for a bespoke sports car.
The Mercedes AMG A Class F1 Edition, or the Renault Clio F1 Sport (without a part of F1 tech, just an inline 4 with a turbo)
dfegan358
dfegan358
-2
Did Ferrari revert back to spec 1 power unit for Monaco?
I think it was only an updated ICE that Ferrari took in Spain so will they take a second mgu-k, Mgu-h and turbo in Canada also?
I think only here will we get an idea of relative power unit gains for the second spec engines of Ferrari and Mercedes. Think Ferrari will be stronger than people think here.
saviour stivala
saviour stivala
2019 power unite elements used Monaco GP before start of qualifying.
FERRARI car number 5 = 2 ICE. 1 TC. 1 H. 1 K. 1 ES. 2 CE.
FERRARI car number 16 = 2 ICE. 1 TC. 1 H. 1 K. 1 ES. 2 CE.
473
dfegan358 wrote:
01 Jun 2019, 17:23
Yes.
sosic2121
sosic2121
hurril wrote:
22 May 2019, 09:45
At 7k rpm pressure goes to 10 bars.
Is this usual for race car/f1 engines?
