sosic2121 wrote:
02 Jun 2019, 09:46
hurril wrote:
22 May 2019, 09:45
This is mildly interesting:
https://www.youtube.com/watch?v=JkCZAzZ ... gs=pl%2Cwn
At 7k rpm pressure goes to 10 bars.
Is this usual for race car/f1 engines?
Thats not charge air pressure! Thats something else!
sosic2121
sosic2121
PlatinumZealot wrote:
02 Jun 2019, 23:00
sosic2121 wrote:
02 Jun 2019, 09:46
hurril wrote:
22 May 2019, 09:45
Someone already mentioned that it's probably oil pressure, so I was commenting on that.
Xwang
Xwang
29
Are the newer engine components (MGU-H, turbo, etc) installed in Canada a second specification or the same specification as the ones used up to now?
sosic2121 wrote:
03 Jun 2019, 19:25
Nothing too unusual, some road cars at/near that.
sosic2121
sosic2121
PhillipM wrote:
09 Jun 2019, 14:07
sosic2121 wrote:
03 Jun 2019, 19:25
I wasn't aware.
Thank you for enlightening me.
Gibbs
Gibbs
https://twitter.com/ScuderiaFerrari/sta ... 9302759425
Unless I'm mistaken throttle bodies or valves before the turbo inlet are banned which means the failure must be waste-gate related?
To me that sounds like a broken hose or something on the airs way to the turbo compressor side.
63l8qrrfy6
63l8qrrfy6
368
I know they said airflow to the turbo but based on the radio exchange it does sound a lot like a boost leak somewhere.
Mudflap wrote:
27 Jul 2019, 17:49
Yep, makes more sense. Binotto clarified that it was related to the intercooler.
63l8qrrfy6
63l8qrrfy6
368
MtthsMlw wrote:
27 Jul 2019, 17:50
Mudflap wrote:
27 Jul 2019, 17:49
At least that's a fairly straightforward fix. The original "bust turbo" diagnosis sounded quite terminal.
saviour stivala
saviour stivala
A leaking boost air pressure pipe was the cause.
@NicolasF1
aleks_ader
90
I have couple of questions about 2019 Ferrari PU:
1. What is underneath gold foil? And why they dint made intake into plenum from front side? Obviously they dint want to waste volume from tank. But in my opinion installation is more crammed in the middle. Sure they have space above MGUH and in that skiny airbox. Two arc shaped pipes from intercooler should outweigh slight position of tank?
2. For intercooler did they have separate water pump or no? For temperature regulation you use valves, because with speed (also circuit and weather dependant) you have different cooling efficiency in sidepod radiator. Hence you need somehow regulate that intake temperature. Or i m wrong.
EDIT: Or they just regulate water flow rate with orbital water pump. Thats how they cool the engine or i m wrong. I know teams uses that type pumps for decades so i m asking to verify my thoughts.
scarbs
scarbs
393
1)Inlet manifold
2) separate pump/cooler/radiator
That means the Ferrari V is incredibly crouded, even more busy than the 2014-2018 PU, because it seems to contain:
-part of the ram air-to-compressor duct, (green in my magnificent drawing) which seems to pass between the intake manifold and the Xenomorph-head-shaped compressor-to-intercooler duct
-part of the intercooler-to-intakemanifold duct (yellow / intercooler is blue)
-part of the inake manifold (purple)
-the MGUH
