Owen.C93 wrote:Well Martin Whitmarsh previously said they had an update for Abu Dhabi if they were still in the title hunt, perhaps something clever they don't want to share unless necessary.
But recently they changed their philosophy and he said they were chucking everything on the car to see if it works, so perhaps that's changed the update plans.
These are the posts that make me laugh. Thank you.Halgovern wrote:I read somewhere ( I think a qoute from Jonathan Neal or someone) that if McLaren wanted to put downforce on its car, they can put buckets of downforce on. But the problem is the car design philosophy, the Mp4-24 is a low-drag, highly efficient car, unlike the Ferrari and the RedBull, which are both high downforce cars. This is why they didn't go for the V-nose like ferrari and redbull, because its a high drag solution for the extra downforce it generates. And obviously this is the reason for the F-duct: high downforce in corners without the resultant drag penalty: so it produces 'efficient' downforce
So if McLaren try and put loads of 'inefficient' downforce, yes, they will be faster through corners but horrendously slow on a straight that their overall performance will be lower. Red Bull and Ferrari can put as much downforce they want, because their cars are designed for a much lower aero-efficiency anyway. This means that for them the extra downforce makes up for the slower straight line speeds, while for the McLaren it doesnt, because they've got so much straight line speed and so little downforce compared to the Bull and the ferrari.
I think this could explain Macca's huge diffuser, because a diffuser is highly efficient: it gives buckets of downforce for very little drag.
Well then, why did McLaren go for a high-efficiency package rather than a high downforce one? seeing that there are more high-downforce races on the calender than low downforce races? I personally think McLaren overestimated the advantage of the F-duct. They've been developing it for 2 years and they knew that it was ridiculously hard to implement on a car which wasn't designed for one (as we saw a lot this year!). And besides, its an aero-dynamisist's dream: high downforce for almost zero drag
Anyway, thats my two cents worth . Hopefully they come up with a high-downforce car for next year.
An aerodynamicly car is an car that has the highest L/D ratio, thus downforce:drag, you are more likely to achieve an very efficient car with an high downforce car .Halgovern wrote:I read somewhere ( I think a qoute from Jonathan Neal or someone) that if McLaren wanted to put downforce on its car, they can put buckets of downforce on. But the problem is the car design philosophy, the Mp4-24 is a low-drag, highly efficient car, unlike the Ferrari and the RedBull, which are both high downforce cars. This is why they didn't go for the V-nose like ferrari and redbull, because its a high drag solution for the extra downforce it generates. And obviously this is the reason for the F-duct: high downforce in corners without the resultant drag penalty: so it produces 'efficient' downforce
Ferrari and Red Bull are only 5kp/h behind, so why wont they put df on for this 5kph, then they would gain much more in the corners.So if McLaren try and put loads of 'inefficient' downforce, yes, they will be faster through corners but horrendously slow on a straight that their overall performance will be lower. Red Bull and Ferrari can put as much downforce they want, because their cars are designed for a much lower aero-efficiency anyway. This means that for them the extra downforce makes up for the slower straight line speeds, while for the McLaren it doesnt, because they've got so much straight line speed and so little downforce compared to the Bull and the ferrari.
Everyone knows that the McLaren diffuser is far from efficient with people even it says it is starving because there isnt enough air to feed the diffuser. also this is just contrasting to what you have said before.I think this could explain Macca's huge diffuser, because a diffuser is highly efficient: it gives buckets of downforce for very little drag.
wesley123 wrote:An aerodynamicly car is an car that has the highest L/D ratio, thus downforce:drag, you are more likely to achieve an very efficient car with an high downforce car .Halgovern wrote:I read somewhere ( I think a qoute from Jonathan Neal or someone) that if McLaren wanted to put downforce on its car, they can put buckets of downforce on. But the problem is the car design philosophy, the Mp4-24 is a low-drag, highly efficient car, unlike the Ferrari and the RedBull, which are both high downforce cars. This is why they didn't go for the V-nose like ferrari and redbull, because its a high drag solution for the extra downforce it generates. And obviously this is the reason for the F-duct: high downforce in corners without the resultant drag penalty: so it produces 'efficient' downforce
Nobody knows this, everything here is just educated guess.wesley123 wrote:Everyone knows that the McLaren diffuser is far from efficient with people even it says it is starving because there isnt enough air to feed the diffuser. also this is just contrasting to what you have said before.
