The yellow cover is going into the intercooler is how i interpret it.
aleks_ader
90
PlatinumZealot wrote: ↑
03 Aug 2019, 14:58
That is airbox to compressor definitely just like @Blackout draw in sketch
scarbs
scarbs
393
roon
roon
412
Honda noped out of that route.
scarbs wrote: ↑
03 Aug 2019, 23:13
https://ibb.co/7KmW5T8
Yes that intercooler to plenum to engine route is much more logical :P
saviour stivala
saviour stivala
scarbs wrote: ↑
03 Aug 2019, 23:13
Where is the MGU-H?.
scarbs
scarbs
393
saviour stivala wrote: ↑
04 Aug 2019, 11:57
scarbs wrote: ↑
03 Aug 2019, 23:13
In the V of the engine ahead of the turbo
scarbs
scarbs
393
04 Aug 2019, 11:57
scarbs wrote: ↑
03 Aug 2019, 23:13
Looks like there is a "equal length runner" set up after the plenum despite only one runner being visible? Is the only way that plenum location would make sense to me. :?:
And look at the diameter of the runner. It must be only one runner we are seeing. The other five are tucked under.
roon
roon
412
Do not doubt the Italians' mastery of noodles.
saviour stivala
saviour stivala
scarbs wrote: ↑
04 Aug 2019, 15:30
04 Aug 2019, 11:57
scarbs wrote: ↑
03 Aug 2019, 23:13
So the turbo shaft 'drive' to/from MGU-H is through the compressor outlet (right through a 90 degree outlet bend.
568
Yes. Compressor "inlet" to be precise.
saviour stivala
saviour stivala
gruntguru wrote: ↑
06 Aug 2019, 00:15
Yea you are right. should have been 'compressor inlet.
scarbs
scarbs
393
05 Aug 2019, 20:32
scarbs wrote: ↑
04 Aug 2019, 15:30
04 Aug 2019, 11:57
In pink...
flip a coin 3 times
Is the MGU-H encased in the piping to the compressor to seal it all off or is there a gap through which air would be sucked in? I assume that wouldn't be an ideal solution.
