Well I'd like to throw in my two cents on this issue of the teams cooling problems. I know most here say they think the problems can be easily solved or that it's not much of a problem but I think it could be. You really have to think about what has happened to see the potential seriousness of this problem.
Re-arranging components inside the car is not as easy as it seems. Remember when designing a car you design and test each component at the best possible location you have. You then place other components around the others. Changing one thing may mean total redesign or placement of the other components. Remember everything was already optimized and designed with the belief that there will be enough cooling around them.
The two cooling fixes they implemented seems like they didn't work [I could be mistaken here because there might have stopped running because of another mechanical problem. I read that a part was seen flying from the back] so the it could still be serious.
Now this one is the real worry. Newey and Horner had to leave on the third day of the test to go rush back for a solution. You don't just leave the first test during a revolution of F1 just because. Something serious must have been discovered, potentially FATAL. So much so that the car may have to be redesigned. I also think Daniel Ricciardo revealed more than he was supposed to. If you read what he said again you'd see that whatever they discovered could be significant.
Now the solution to this might be simple enough I don't know.. Good luck to them and hopefully we will see them in the next test with a working power unit so they could get on with it. As much as I am a Mercedes fan competition is best...
