[ 2020 ] Aston Martin RedBull Racing F1 Team - Honda
Viruzpunk
Viruzpunk
Re: [ 2020 ] Aston Martin RedBull Racing F1 Team - Honda
Anthony Burrows, test team manager.
Marti_EF3
56
What do you think about it? Could that bangs be something like that? Or it's only a clickbait... :?
What do Red Bull and Newey plot with the Honda engine?
The Red Bull team caught the attention of those who stopped to listen to the engines during the F1 preseason tests. What does Newey plan with the Honda?
Anyone with a fine ear would hear it immediately. You didn't have to be an F1 expert to realize that the sound of the Honda power unit in the Red Bull RB16 was completely different from everyone else in curve 10 of the Circuit de Barcelona-Catalunya .
So we went to that curve to see what a professional GT driver and a former F1 technical director had told us. Adrian Newey, along with Honda engineers, could have done his thing.
While the rest of the cars, after finishing the braking of the opposite straight line leading to curve 10, went with the 6-cylinder engine in full release, the Red Bull with Max Verstappen at the wheel managed to turn starting that sector 3 going perfectly in line, but emitting a murmur-like engine sound, as if the one- or two-cylinder butterflies remained open and the unit continued to deliver torque at the entrance of the slowest curve of the Catalan circuit.
The mind immediately leads to remembering the blown exhausts that Red Bull used with Sebastian Vettel in 2011 and 2012, achieving the exhaust more or less a second more performance, increasing the load on the rear diffuser with hot gases.
But those years the cars had an 8-cylinder aspirated 2.4-liter engine with considerable gas flow, so much so that with a proper calibration of the exhaust valves it was possible to produce a blowing effect with the Renault engine . Basically these were always open, even if minimally, as to allow the combustion of air + gasoline in some cylinders and allow the blown exhaust effect.
Now the situation is very different because the adoption of the turbo removes a lot of energy from the gases and the unique exhaust pipe from the beginning of the hybrid era has moved up, away from the ground to prevent it from feeding the diffuser .
So what has Honda been experimenting with? In the past, Ferrari and Renault took on the challenge of opening the turbo exhaust valve with specific strategies to blow at low speeds with the two additional small leaks (adopted in 2016 to improve noise), in order to improve efficiency by influencing in the lower part of the main profile of the rear wing and helping to extract the flow from the central part of the diffuser.
The effect is obviously not comparable with that produced by the 8-cylinder aspirate, but in F1 there is nothing that cannot give a performance advantage. The blowing, in fact, could be generated by the thrust of the compressor which in the release phase of the 6 cylinders is activated by the MGU-H , the electric motor that recovers turbo energy.
Basically, there would be an extra compression of air in the combustion chamber that would be "fired" to the leaks without fuel injection to generate the explosion. Combustion without fuel.
The turbine, therefore, would work as if it were preloaded, and the extra blown air (that is, without residual combustion gas) would be released by the discharge valve that would remain open, blowing a more energetic flow towards the rear wing. This would produce an aerodynamic advantage in slow corners and every time the throttle is closed.
This solution would lead to determine a different gas flow rate in the two leaks to exploit the blow with increasingly complex and effective strategies. But in the case of the Red Bull RB16, it seems that the 'explosion' does occur. What has Newey invented this time? The RB16 is a laboratory of interesting solutions and Honda seems to have participated in the innovation.
https://es.motorsport.com/f1/news/truco ... 0/4707158/
bigblue
Ummmm, ... clickbait. It's been doing the cylinder-cut for multiple seasons now. Is there any reason to believe what happened in testing was different to what came before ? (Isn't it a bit more pronounced, but not actually different ?).
Marti_EF3
56
I was thinking the same, but what is "new" is that bangs while downshifting and entering slow turns...
_cerber1
262
McLaren and Honda had a mode of engine operation that worked well with the monkey seat, creating additional downforce.
etusch
131
If I didn't see wrong Max is in front until last chicane
GPR-A
37
etusch wrote:
03 Mar 2020, 10:38
https://youtu.be/JvdTVHu9iuE
That is because both videos are not synced properly. At the start itself, Max was ahead in this video.
etusch
131
GPR-A wrote:
03 Mar 2020, 10:58
etusch wrote:
03 Mar 2020, 10:38
https://i.imgur.com/0oXoq9Z.jpg
Yes, I saw it now. Thank you
Juzh
161
etusch wrote:
03 Mar 2020, 11:05
GPR-A wrote:
03 Mar 2020, 10:58
etusch wrote:
03 Mar 2020, 10:38
here's a proper one
https://streamable.com/oq3sj
etusch
131
Juzh wrote:
03 Mar 2020, 12:54
etusch wrote:
03 Mar 2020, 11:05
GPR-A wrote:
03 Mar 2020, 10:58
here's a proper one
Thank you @juzz. Great job. In this one last chicane and 2 turn before it, looks merso makes difference. At other part, I think redbull is better or same at least. If they can find a way to be faster in slow turns we can see a new wdc.
Jaisonas
Jaisonas
Redbull released an onboard on their facebook page. Besides the bad sound mixing, what seemed interesting to me, was the oscillations when he shifted to 7th gear at the beginning of the video and at 1:21
etusch wrote:
03 Mar 2020, 13:20
Juzh wrote:
03 Mar 2020, 12:54
etusch wrote:
03 Mar 2020, 11:05
here's a proper one
They'll have a new rear wing which should help. Oh and everyone will be on the same fuel load and tires as well as the same time of day.
That didn't happen in testing.
Jaisonas wrote:
03 Mar 2020, 13:28
https://www.facebook.com/redbullracing/ ... 463342633/
Oscillations = car skidding on the ground.
Jaisonas
Jaisonas
godlameroso wrote:
03 Mar 2020, 14:24
Jaisonas wrote:
03 Mar 2020, 13:28
Skidding at 300kph? I know honda is strong but come on :lol:
Besides the sound is similar to the 2018 toro rosso oscillations with the gearbox
GhostF1
GhostF1
110
Jaisonas wrote:
03 Mar 2020, 13:28
That is the biggest hint they are running detuned. You can hear it through the exhaust as well on some of the videos. They did it last year as well when they said they were running in a lower power mode during practice. It'll clear up come Melbourne.
