How?djos wrote:Yep I know how a normal exhaust brake works using the valves but surely a similar effect can be achieved using the turbo?
Stopping the exhaust gases from moving freely from the engine will I postulate create back pressure and a compression braking like effect - likely not as strong as using the valves but possibly enuf to be useful in an F1 engine.Holm86 wrote:How?djos wrote:Yep I know how a normal exhaust brake works using the valves but surely a similar effect can be achieved using the turbo?
Why would you have an expensive and heavy MGU-H in the first place if you do not use it to control boost and generate electricity. Just to spool the turbo up? That would not fit to anything we know.bhallg2k wrote:There's a difference between the MGUH and the turbine itself, and it's far from given that teams will use the MGUH to control boost; some of us still think a relatively simple wastegate is the obvious solution....
No not every generator can be used as a motor. It demands a permanent magnet and DC.djos wrote:Any generator can be a motor, just operate it in reverse buy supplying current.
If we assume that the engine will have a throttle - which it surely will have due to banning variable valves - then the engine braking should simply work by cutting the injection. But that would also cause the turbo to spin down due to lack of exhaust energy. So it is difficult to imagine how this works without more information. It is not desirable to spin down the turbo if you have to spin it up again when you have to power out of the corner.djos wrote:Stopping the exhaust gases from moving freely from the engine will I postulate create back pressure and a compression braking like effect - likely not as strong as using the valves but possibly enuf to be useful in an F1 engine...Holm86 wrote:How?djos wrote:Yep I know how a normal exhaust brake works using the valves but surely a similar effect can be achieved using the turbo?
WhiteBlue wrote:Why would you have an expensive and heavy MGU-H in the first place if you do not use it to control boost and generate electricity. Just to spool the turbo up? That would not fit to anything we know.
Just watched the episode.Holm86 wrote:No. Because he said that the turbo would help brake the engine. Which he also said sounded a bit strange to have the turbo braking the engine. To me it does not make any sense.
IMO they will cut ignition and fuel when off throttle, but keep the throttle bodies open if this is allowed. And then use the MGU-K for braking the engine. This cold blowing will keep pumping air though the engine, helping the turbine to keep spinning. Then you can either use the MGU-H to harvest more energy from the turbine, or let the turbine spin freely so you don't have to use as much energy spinning it back up when back on the throttle.WhiteBlue wrote:
I agree with Holm that the MGU-K is much better suited to the purpose of braking.
Watched it last night so couldn't remember precisely how he said it. Just thought it sounded a bit wired.wuzak wrote:Just watched the episode.Holm86 wrote:No. Because he said that the turbo would help brake the engine. Which he also said sounded a bit strange to have the turbo braking the engine. To me it does not make any sense.
He is saying that they can slow the turbo using the MGUH (or ERSH, as he says), which generates energy that can be stored and also increases back pressure on the engine, which will help engine braking. Not sure how much that will work.
Also, just thinking aloud, it woudl seem that if the engine has more engine braking then there is less for the MGUK (or ERSK) to do.
It still does not make much sense to me. If the back pressure is increased it would mean that fuel is still injected. Without fuel you do not get significant exhaust energy and heat to have the turbine spun up. So it means you use fuel and that would not be consistent with engine braking. It does not fit.wuzak wrote:Just watched the episode.
I am pondering this and it might be the answer. If the engines is running at 10500 rpm and at 21psi boost pressureHolm86 wrote:IMO they will cut ignition and fuel when off throttle, but keep the throttle bodies open if this is allowed. And then use the MGU-K for braking the engine. This cold blowing will keep pumping air though the engine, helping the turbine to keep spinning. Then you can either use the MGU-H to harvest more energy from the turbine, or let the turbine spin freely so you don't have to use as much energy spinning it back up when back on the throttle.WhiteBlue wrote:
There's so many variables in how to harvest and use the electric energy next year. Pretty exciting.
No, it does not.WhiteBlue wrote:If the back pressure is increased it would mean that fuel is still injected.
Firstly, the turbine has inertia. It's tendency is to want to keep spinning.WhiteBlue wrote:Without fuel you do not get significant exhaust energy and heat to have the turbine spun up.
