bhallg2k wrote:Far from it. In fact, I suspect the letterbox inlet is a part of their Daffy Duct solution.
The general consensus about the Mercedes DDRS is that air is fed from the rear wing inlets to the front wing upon the activation of DRS. I've never bought into that line of thought, though, because it just doesn't make sense to route that high pressure flow along the entire length of the car to blow the front wing. I think the Mercedes DRS inlets serve as the fluidic switch that allows high pressure air from the chassis scoop on the nose of the car to supply the high pressure air. That's far more sensible in my opinion.
I don't yet know how the letterbox inlet factors into Red Bull's solution except that I'm pretty damn sure it plays a role somehow, somewhere.
I've never bought into the Mercedes DDRS concept either and believe that they actually use the airflow from the nosecone hole to blow the underside of th front wing when DRS is inactive and when DRS is activated it pulls the airflow past the FW pillars stalling the FW. The reason they blow the FW under normal circumstances is it allows for a steeper AoA on the FW as the blowing aids attachment/reduces boundary layer.
To this end I have a slightly different theory on RBR's RW-DDRS which I posted about last night:
http://somersf1.blogspot.co.uk/2012/10/ ... sible.html
Red Bull could very well have found a good way of manipulating the exhaust plume to better achieve their original goals in the region. I think DDRS could be part of a curve ball in that reducing drag isn't the largest part the system plays and with the 2013 ban on Secondary function DRS the other teams may just dismiss it.
I'm probably wrong, just wanted to share my theory.
