2022 Mercedes-AMG | Petronas F1 Team
Re: 2022 Mercedes-AMG | Petronas F1 Team
Big Tea wrote:
06 Sep 2022, 12:25
Just_a_fan wrote:
06 Sep 2022, 12:23
mendis wrote:
06 Sep 2022, 10:42
Are you defending online toxicity and your comparitson to diminish such behavior is what happened to a woman in a crowd of morons?
I'm not defending anything. There is, however, no comparison between online trolling/abuse and the physical abuse of someone. And it wasn't just one woman, it was several women. And the morons carrying out the physical abuse all appeared to have a specific allegiance.
None of this is good. It's all bad. It's bad for the sport as a whole and it's bad for the vast majority of fans who just want to enjoy F1 no matter what their own team/driver preferences may or may not be.
I know it is easier said than done, but don't read them. If these people do not get recognition they may bugger off elsewhere
Exactly so - you can ignore tweets. Someone groping you is rather more difficult to ignore.
El_KaPpa
El_KaPpa
Goblin42 wrote:
06 Sep 2022, 12:51
Moving on to monza, on the drag levels that mercedes has it might be the first double Q1 knockout for mercedes in the turbo hybrid era, the RB is constantly 10 to 15kph faster on the straights, best solution is to take an engine penalty and write off the weekend, but this sport might surprise us ,keeping high hopes
That's also what I was thinking about but as I understand they don't care much about engines as they seems reliable but to gamble and test different setups to get that victory
Of course I struggle. I just don’t quit.
Hammerfist
Hammerfist
Goblin42 wrote:
06 Sep 2022, 12:51
They will be far away but they will easily qualify out of q1 and make q3. Besides Redbull and Ferrari only Mclaren and alpine can outqualify them. Even if they are draggier than most teams there are still corners at Monza and they can make up a lot of lap time there on those lower ranked teams.
I can see max outqualify them by one sec though. What will be interesting to see is if they can still challenge Ferrari on race day.
232
Goblin42 wrote:
06 Sep 2022, 12:51
I think they will be second fastest there. The track is flat. They will have little trouble with suspension setup and ride.
The can bias the car to very low drag without consequences. Remember in the earlier part of the season the car had overheating issues. I think they can close up the holes some more here at monza and improve efficiency.
The car should also be good in the chicanes.
So I am hoping they can challenge here. The track should suit Lewis's driving style.
continuum16
51
Goblin42 wrote:
06 Sep 2022, 12:51
Not double Q1, but I would not be shocked to see them qualify like 5th and 7th and be split by the Alpines. They just have to make sure not to get stuck behind Albon's Williams on Sunday, either off the start or in the pit stops, because it will probably be impossible to overtake.
- Mark Twain
Cs98
Cs98
37
Hammerfist wrote:
06 Sep 2022, 19:15
Goblin42 wrote:
06 Sep 2022, 12:51
McLaren are also draggy. I'd be more worried about the low drag cars like AM, AT, even Williams. They'll obviously be much slower in the corners, but when it's 80% full throttle that matters less, especially in Quali.
Williams are actually fairly decent in the slow speed corners. They were good through and out of La Source at Spa, though that required a setup compromise so hard to tell if that will continue
My expectation is that Merc will not have a problem outqualifying all but alpine
Mostlyeels
Mostlyeels
Cs98 wrote:
06 Sep 2022, 21:18
Hammerfist wrote:
06 Sep 2022, 19:15
Goblin42 wrote:
06 Sep 2022, 12:51
AM look to have taken a step forward since the break.
Rodak
Rodak
37
Hammerfist wrote:
06 Sep 2022, 19:15
Goblin42 wrote:
06 Sep 2022, 12:51
I wouldn't bet everything on that, the Williams has been pretty quick on high speed tracks. Having said that, they do have Latifi.......
napoleon1981
napoleon1981
e30ernest wrote:
05 Sep 2022, 04:49
napoleon1981 wrote:
05 Sep 2022, 04:41
Big Tea wrote:
04 Sep 2022, 18:09
I did suspect that maybe he was baiting Max to pass him before the line.
These two drivers are the craftiest ever and consider things we only think of later.
That would be a Lewis move. There is some onboard with Max lifting to avoid passing Lewis. I would be interested to see the Lewis throttle trace. The speed differential was unusually high quite sudden with Max pulling out of the draft early. I suspect Lewis lifted as well to draw Max in an error.
Someone posted the telemetry on the race thread. Lewis was flat out on the throttle on the restart. Max was just that much faster on the straight.
Thanks, yeah he was flat on the telemetry. Sounds like he might have been in the wrong engine mode.
Hammerfist
Hammerfist
Rodak wrote:
07 Sep 2022, 01:35
Hammerfist wrote:
06 Sep 2022, 19:15
Goblin42 wrote:
06 Sep 2022, 12:51
Williams is not a threat. Come on they are the second slowest team. I can see slbon make it to q3 but nothing more. Again its not just straight line speed at Monza.
georgekyr
georgekyr
napoleon1981 wrote:
e30ernest wrote:
05 Sep 2022, 04:49
napoleon1981 wrote:
05 Sep 2022, 04:41
Or the right one if he was trying to get Max to pass him before the starting line. Choosing a mode that ensures he would be with 100% throttle and Max able to pass him before the starting line. I believe the mode was part of the strategy Lewis chose which did not work because Max lifted his foot momentarily from the throttle...
Στάλθηκε από το SM-A528B μου χρησιμοποιώντας Tapatalk
Jdn1327 wrote:
07 Sep 2022, 08:12
Hunt and Lauda...
You do know that Hunt and Lauda were actually friends, don't you?
Cs98
Cs98
37
Hammerfist wrote:
07 Sep 2022, 05:21
Rodak wrote:
07 Sep 2022, 01:35
Hammerfist wrote:
06 Sep 2022, 19:15
Goatifi is not a threat. Albon might be in quali. Obviously in the race he will be slower, but on new softs and with better straight line speed I can see him being a threat.
Cs98
Cs98
37
Just_a_fan wrote:
07 Sep 2022, 09:53
Jdn1327 wrote:
07 Sep 2022, 08:12
Hunt and Lauda...
To begin with and in the end. I do believe they fell out somewhere in the middle.
