Sorry, edited.jz11 wrote:red300zx99, did you read my post as a whole or you just comment on single sentences without context?
oh, I meant low gear ratio, there seems be always a confusion about that, that is why I specified gear numbers in the bracketsred300zx99 wrote:Sorry, edited.jz11 wrote:red300zx99, did you read my post as a whole or you just comment on single sentences without context?
Some of the stuff you said is somewhat confusing. Low gear(5-7)...maybe a typo, shouldn't it be high gears(5-7)? Low gear to me is 1-3, gears used in low speed. Saying high gear instead changes the meaning for me, your 'normal accelration' becomes mid-high speed exits...I was reading your 'normal acceleration' to mean low speed traction limited stuff.
i.e. keep the exhaust valve open longer on the compression stroke.hardingfv32 wrote:Please expand.... I thought the pneumatic system dealt with valve closing.Raptor22 wrote:Altering the torque is fairly simple with a pneumatic valve train. simply drop the exhaust valve for a microsecond and bleed off cyclinder pressure.
Brian
5.9 Variable geometry systems:
5.9.1 Variable geometry inlet systems are not permitted.
5.9.2 Variable geometry exhaust systems are not permitted.
5.9.3 Variable valve timing and variable valve lift systems are not permitted.
Dragonfly wrote:Raptor22
Would you please describe in more detail how the exhaust valve is held open longer?
Yeah, I asked the question to Raptor22, because I know with current engines it's forbidden. And we are talking about the current Renault engine. So all theoretical possibilities should be left aside.jz11 wrote:sometimes it helps to read the regulations
Raptor..You talking about the ill fated Renault attempt that was deemed too heavy and cumbersome and that they couldn't get to work at these RPMs?Some of the most common is a magnetically controlled system:
Dragonfly wrote:Yeah, I asked the question to Raptor22, because I know with current engines it's forbidden. And we are talking about the current Renault engine. So all theoretical possibilities should be left aside.jz11 wrote:sometimes it helps to read the regulations
