Williams FW38 Mercedes
Re: Williams FW38 Mercedes
Contrary to what we were told the only image i could see of the new FW was in Massa's car.
In FP2 both cars are running old FWs.
Did it get damaged on Massa's offs?
Also, as far as i can tell, cars seem to have reverted to pre-season design on the beam wing knock off.
I have no idea what's going on right now...
LookBackTime
LookBackTime
472
Williams: punctures caused by a problem in the circle
"Technicians from Grove, however, have finally clarified the mystery: to determine the damage to the Pirelli tires (wholly innocent) would be a problem to look for: an air leak caused the deflation of the tire."
https://translate.google.com/translate? ... edit-text=
LookBackTime
LookBackTime
472
Sevach wrote:Contrary to what we were told the only image i could see of the new FW was in Massa's car.
Confuse opposition ! I guess :)
On serious note : they were forced to change to an old floor (Massa's car) so they have to use an old nose and fw.
LookBackTime
LookBackTime
472
On Sky F1 Bottas said "rim clearance" issue caused Massa problems.
From the Aurosport Forums:
Massa Wheel
LookBackTime
LookBackTime
472
Williams failures caused by brake duct changes
http://www.motorsport.com/f1/news/willi ... es-687220/
LookBackTime
LookBackTime
472
What is the "bumpy stuff" behind tyre temperature sensor (see above image)?
LookBackTime
LookBackTime
472
Massa's Chinese GP practice tyre blows due to Williams set-up error
http://www.autosport.com/news/report.ph ... etup-error
cramr
cramr
LookBackTime wrote:What is the "bumpy stuff" behind tyre temperature sensor (see above image)?
I'd say a video camera to record some diffuser or rear suspension movement during the lap (only to be used in test)
LookBackTime
LookBackTime
472
Bottas said that Massa had the new front wing in FP1, but the tyre failures broke it. So both cars will now have the old fw for the rest of the weekend.
Martin_F
22
I read on AMuS, that they are evaluating to see if the wing could be fixed. But if they can't we'll be back to square one.
LookBackTime
LookBackTime
472
Bite-size tech: Williams FW38 front brake duct amendments
http://www.motorsport.com/f1/news/bite- ... ts-687720/
LookBackTime
LookBackTime
472
Williams: Bottas does not use the ultra short nose
