Red Bull RB16
gandharva
252
Re: Red Bull RB16
Engine sound different this year. Much more dull (bit like Renault), but also very high pitched turbo noises.
Holm86
249
Re: Red Bull RB16
gandharva wrote:
03 Jul 2020, 12:24
Could it be a matter of microphones??
gandharva
252
Re: Red Bull RB16
Maybe, but the Merc is not that different to last year.
Holm86
249
Re: Red Bull RB16
gandharva wrote:
03 Jul 2020, 12:30
Okay sad then, the Honda had a very specific noise last year ...
Marti_EF3
56
Re: Red Bull RB16
It still have that noise. When I was on the test on February, it was clear when a Honda PU was near. Also with that bangs that still are today
Jaisonas
Jaisonas
Re: Red Bull RB16
gandharva wrote:
03 Jul 2020, 12:24
Its the microphones, as per tradition, the onboard sound quality has gotten even worse this year. Ferrari's onboard was just screeching distortion, Verstappen's f1tv stream was a bassboosted exhaust, in general its sh*t
Bandit1216
21
Re: Red Bull RB16
Don't get me wrong guys, because I would like to hear screaming engines back but;
When you have a hybrid engine limited in efficiency, I would like it to make no noise at all. No heat loss either if that would be possible. Making a lot of noise is not a good sign since 2014. Transferring part of the heat and even noise back into energy using an electrically coupled turbo compound engine is the whole reason they got so quiet relative to the na engines.
Think about it. If the honda would make no noise at all, and no heat loss either, It would be 2000 hp and no radiator needed. That would be a slim bodywork. They would need to ad a horn to make themselves heared when lapping every 3 laps.
I know this all is a bit of BS, but please stop thinking you can hear horse powers somehow.
GioKer32
GioKer32
Re: Red Bull RB16
Verstappen's Redbull is using a new nose...Check the pylons that link the nose to the wing :shock:
Re: Red Bull RB16
I don't think it is possible to fit an engine in that tight of an engine cover.
Source
Re: Red Bull RB16
GioKer32 wrote:
03 Jul 2020, 16:29
Good catch. They tested both versions today. This is the new one with the mounting pylons beneath the nose and the "duct" layout is different.
Launch spec:
Re: Red Bull RB16
The 2 noses
Old
New
Re: Red Bull RB16
Re: Red Bull RB16
That's like 105mm rear ride height and ~35 at the front.
zibby43
zibby43
Re: Red Bull RB16
A distant peek at the diffuser/underfloor:
GhostF1
GhostF1
110
Re: Red Bull RB16
You guys are losing it. The Honda still sounds unreal, if anything more intense this year. Not sure what onboards you're seeing!
I'll see if I can get a grab from a Hotlap and post.
