Concept power units from 2030
mzso
mzso
65
Re: Concept power units from 2030
Tommy Cookers wrote:
16 Apr 2025, 13:31
mzso wrote:
16 Apr 2025, 11:25
So it could be compact and low vibration.
a compact X4 wouldn't be close to 90 deg and so would vibrate eg more than any car (3 or more cylinder) engine
If the opposing pistons are symmetrical, why would it vibrate?
ispano6
toraabe wrote:
15 Apr 2025, 18:55
Forget that. Two stroke with turbo instead..
How about hydrogen rotary? Might be a good R&D challenge that Aramco could get on board with, considering their focus on blue ammonia/hydrogen. Maybe have to look farther ahead to 2040...
648
ispano6 wrote:
17 Apr 2025, 22:06
the rotary might seem to have excessive combustion chamber area but .....
gaseous fuels have a wider explosive range and so can be run much leaner but ....
you'd need a 2 stage compressor
470
mzso wrote:
12 Apr 2025, 23:00
While on the the topic of smaller/lighter engines. I wonder why no-one ever mad an X-4, or X-8 engine. (For racing anyway)
https://images2.imgbox.com/29/8b/6WVOL7cJ_o.gif
CoG too high, inconvenient exhaust and inlet placement.
Gearbox will be too high too.
In the current regulations, the crankshaft centreline is 90mm above the reference plane, and the CoG must be a minimum of 200mm above the reference plane.
