outer_bongolia wrote:I have another "is it possible question". Will there be enough "negative pressure" at that location to actually make it work like an exhaust-side turbo to increase the thermodynamic efficiency and basically increase the engine performance at that location? Some of the drawings that I saw kind of suggested that the pressure over there could be as low as anywhere else in the bodywork. 1 HP is 1 HP, especially if you're running a Renault engine...
It's not anything like a turbo for sure but If you mean as in some type of exhaust pulse effect, for naturally aspirated engines that is a complex topic. I don't know anything about acoustics, there might be others than can answer that. But in terms of having a lower pressure outside the exhaust. A lower pressure might increase the thermodynamic efficiency somewhat because it will be easier for the gas to be pumped out of the exhaust. The exhaust leaves the chamber easier and faster. I guess you can get more fresh air into the engine during the time at which the exhaust valve is closing and the intake valve is about to open (valve overlap) so there might be a better combustion efficiency too. But with these complex motions and phenomenons that are occurring in the fluid it is hard to say you gain more power, you can even cause the engine to loose power too.
If it was all to have the lowest pressure, all the teams would put 5 inch diffuser cones on the exhaust pipes. But they don't so maybe you can say that there is an optimal pressure in the exhaust collector that they must have; not high and not too low.
Overall I
think the effect on the engine from putting the pipes down near the floor is negligible. Because the flow through those F1 exhaust pipes are so unrestricted and the pulses are so rapid and violent that the slight drop (or rise) in pressure by merely pointing the exhaust in a different direction is minimal.
If it the engine was turbo charged though, you want that pressure as low as possible! That is because turbines operate on pressure and temperature difference. But these cars are naturally aspirated so yes, I think it just moving the pipes down is negligible. If you point the pipe FORWARD into the breeze, now that is not negligible! That is whole different magnitude of pressure there.
